Author Topic: mamemarquees CPO question  (Read 1754 times)
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« on: May 25, 2005, 01:49:38 pm »
I've done some searching and not found this specific answer regarding the polycarbonate coated control panel overlays from mamemarquees.com.
Just how thick are they? I have a 5/8" panel to which I am adding a 1/8" sheet of lexan. Under the lexan I want the control panel overlay, and I'm curious how thick the whole thing will be when that is done.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Re: mamemarquees CPO question
« Reply #1 on: May 25, 2005, 02:07:38 pm »
Thickness, at the most is between 1/16 and 1/32 of an inch. It's really like a very THICK high quality poster.  I didn't put lexan over mine simply because I was satisfied with the quality of the coating and felt it wasn't necessary.
The lip around the edge made by the t-molding is noticeable, but certainly not a neusance and not something that's going to come loose or cause a problem.
gw71mgb
  • Last login:July 10, 2007, 10:19:44 pm
  • My First Cab is Almost Done!
« Reply #2 on: May 25, 2005, 05:48:55 pm »
I e-mailed Scott at Mame Marquees that very question a few weeks ago:
"Pretty thin, around 11mils which is roughly 1/75th of an inch."
11 mils is .011" thick.
-gary
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #3 on: May 25, 2005, 06:06:49 pm »
It's not intended to be used under lexan.  The colors are not that bright and not nearly as good as the colors for their sideart.  I bought a set from them and never used the cpo because the color was so dull.  I have heard he will print it differently if it is intended to be under lexan AND I have heard that it looks great.  Be sure you talk to scott about it.
********IMPORTANT EDIT**************
It appears I got in under the old system and his CPO's are different now.
Check out the offer two posts down!!!  I should also restate how unbelievable my side art looks.
oh yeah ******(TM) held by Koolmocraig
« Last Edit: June 10, 2005, 01:42:43 pm by monkeybomb »
Veinman
« Reply #4 on: May 25, 2005, 06:45:56 pm »
Interesting. I guess it's a good thing I will be cutting my lexan prior to ordering then. That way if I end up ruining my Lexan I can get the standard CPO, otherwise I'll get the brighter material.
He really needs to beef up his FAQ. ;D
scottp
  • Last login:August 23, 2016, 08:52:04 pm
    • Mame marquees and Side Art
« Reply #5 on: June 10, 2005, 07:49:41 am »
Monkey, not sure when you ordered, but I have changed my polycarbinate laminate recently and it is much brighter.
http://www.gameongrafix.com
10% off Coupon for BYOAC members, just type in BYOAC at checkout
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #6 on: June 10, 2005, 01:35:31 pm »
Monkey, not sure when you ordered, but I have changed my polycarbinate laminate recently and it is much brighter.  I would be happy to re-print it for you?
www.mamemarquees.com
Talk about great customer service!  I know Scott will be getting my business when it comes time to print my artwork.
-Ace-
I want my own arcade controls!
« Reply #7 on: June 10, 2005, 01:53:12 pm »
Mine came out nice & bright, see here for a few pics: http://forum.arcadecontrols.com/index.php/topic,18812.80.html
I'm very pleased with it :)
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #8 on: June 10, 2005, 07:00:05 pm »
Underway: Joey's Arcade
