Author Topic: vertical game on horizontal monitor too small  (Read 1880 times)
mohrt
  • Last login:June 03, 2011, 02:32:42 pm
  • mmm... mame.
« on: May 20, 2005, 12:20:04 pm »
I have a WG D9200 and ArcadeVGA card (older one), running on Windows XP. I'm using the windows version of mame. I tried both avres and the mame resolution tool, and I'm having troubles with the vertical games. btw I read quite a few posts about this subject, but didn't find the exact same issue. Many people have problems with clipped or squished game screens, but my screen is just too small.
When I run a vertical game such as mspacman, it shows up in the middle of the screen and there is about 6 inches of black above and below the game. If I enable hardware stretch it does fill the screen, but I lose the crisp quality of my D9200. Rotating the monitor is not an option in my setup, so displaying vertically on a horizontal monitor is the way I'll have to go.
So my question, is there a resolution/setting that will make the game display bigger without the hwstretch, or do I just live with the small screen?
I tried different resolutions from the command line:
> mame mspacman -nohws -resolution 288x224
> mame mspacman -nohws -resolution 224x288
> mame mspacman -nohws -resolution 352x288
All of these bring up the same thing, same resolution in the middle of the screen.
TIA
AlanS17
    • AlanS17
Re: vertical game on horizontal monitor too small
« Reply #1 on: May 20, 2005, 12:24:42 pm »
Try running it at a resolution that Windows is more familiar with like 640x480.
desmatic
  • Last login:June 25, 2006, 02:25:53 pm
    • Easy MameCab
« Reply #2 on: May 20, 2005, 01:40:51 pm »
TIA
Don't expect vertical games to very look good on a D9200 Windows ArcadeVGA setup.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #3 on: May 21, 2005, 05:29:05 am »
Since that config is also the route I'm likely to take, what would you recommend as the best way to setup and display vertical games on a horizontal monitor?
desmatic
    • Easy MameCab
« Reply #4 on: May 21, 2005, 05:57:24 am »
If you've got a standard resolution arcade monitor, then arcadevga in windows does a decent job of displaying vertical games.  On a d9200, however, vertical games should be pixel perfect, but you'll need to run either Linux or DOS.  While I'd personally recommend using an Nvidia card for a Linux setup, arcadevga works just fine in X11.
