Author Topic: Help me buy a good MAME system  (Read 14144 times)
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« on: March 31, 2005, 03:32:47 pm »
Here's a couple of combinations I am looking at
if you guys have any better ideas I'd like to hear 'em
AMD Athlon 64 3000+, 512KB L2 Cache 64-bit Processor - Retail
Item#    N82E16819103486  -  $146.00
WINTEC AMPO 184-pin 512MB DDR PC-3200, Model 35145588-P - Retail
Item#    N82E16820161615   -  $36.49
MSI "K8T NEO2-F" VIA K8T800 Pro Chipset Motherboard for AMD Socket 939 CPU
Item#    N82E16813130469R  -  $54.00
Rosewill Value Series 300W Dual Fan Power Supply for Intel and AMD systems, Model "RV300" -RETAIL
Item#    N82E16817182001  -  $13.99
Month-End Blowout Sale!
Intel Pentium 4/ 2.66 GHz 533MHz FSB, 1MB L2 Cache Processor - Retail
Item#    N82E16819116193  -  $133.99
ASRock "P4V88 RAID" VIA PT880 Chipset Motherboard for Intel Socket 478 CPU
Item#    N82E16813157034R  -  $25.00
« Last Edit: March 31, 2005, 04:39:27 pm by IntruderAlert »
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
Re: Help me buy a good MAME system
« Reply #1 on: March 31, 2005, 03:38:23 pm »
chip seems like overkill... and obviously you are missing a HD
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
IntruderAlert
    • Intruder Alert
« Reply #2 on: March 31, 2005, 03:45:11 pm »
I have a hard drive and ArcadeVGA already
This stuff is really all I need
I want to make sure I'll be able to run most games at 100% but if it's overkill please make some suggestions
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #3 on: March 31, 2005, 03:58:40 pm »
if I were you I wouldn't cheap out on the powersupply.  Antec, Sparkle and a few others make quality, affordable PSUs.
-Ace-
I want my own arcade controls!
pointdablame
« Reply #4 on: March 31, 2005, 04:12:54 pm »
-Ace-
listen to this man.
Antec, Enermax, Sparkle, even Vantec..... don't cheap out on a powersupply.
I've never heard of your ram either, but it be just fine.  I'd see what the price diff is for a comparable stick of Kingston or Corsair Value ram though.
My .02
first off your and idiot
IntruderAlert
    • Intruder Alert
« Reply #5 on: March 31, 2005, 04:23:26 pm »
I forgot to mention that this stuff is going inside my cab and I have no plans for using it for anything except MAME
The memory and power supply have gotten good reviews on newegg even though they are cheap
but I realize that reliability is important and I appreciate you guys pointing that out
I should also mention that both of the motherboards I am looking at are refurbished which is why they are so cheap
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #6 on: March 31, 2005, 04:55:44 pm »
IMO it's not worth spending that much.
I'd just grab a used mobo/cpu/ram bundle off eBay for a fraction of the price you'll be paying for that lot, especially if you already have a couple of the bits you need.
Boot sales and markets are also a good place to pick up used systems. I bought an Athlon 2000+ system (cpu/mobo/gfx card/40gb hdd/cd-rw/floppy/case/psu) for
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #7 on: March 31, 2005, 05:19:29 pm »
What kind of games are you trying to play?  That can help a lot of us "guide" you.
With that said.  Get the AMD64.  Its "speed now", will be a big help with keeping things cool! Find a good Antec Case/PSU combo.  Believe me it is easier to hack your case in to the mame cab.  Simple things like the drive bay chassis and CPU tray are total time savers, plus I have never gotten a bad Antec PSU.
Later,
d
Nothing witty here...move along.
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #8 on: March 31, 2005, 06:36:51 pm »
Athlon 64's start at about $100... that's way too much to spend on a cpu for a mame system, regardless of the speed step bulls**t they pimp with it.
IntruderAlert
    • Intruder Alert
« Reply #9 on: March 31, 2005, 07:07:38 pm »
after reading topics like this one:
http://forum.arcadecontrols.com/index.php/topic,14155.0.html
..i came to the conclusion that I would need at least 2ghz to run the latest games
that's why I'm looking at the P4 and Athlon 64 cpus greater than 2ghz
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #10 on: March 31, 2005, 07:17:08 pm »
yeah unless you wanna play killer instinct 2 at full speed  ::)
need some powah!
IntruderAlert
    • Intruder Alert
« Reply #11 on: March 31, 2005, 07:19:30 pm »
so you agree?
any of the new CHD games are going to need at least 2ghz?
SOAPboy
  • ..::GeeK::..
« Reply #12 on: March 31, 2005, 07:21:26 pm »
so you agree?
go for it.. if i had the cash my old 2.8c P4 (which runs EVERY game ive thrown at it at full speed), would be in my mame machine..
if you have the money, itll never hurt put it in a cab.. ^_^
Tho, the power supply.. hmm.. id grab a 50$ Thermal take pure power.. Great psu, cheap, and such
IntruderAlert
    • Intruder Alert
« Reply #13 on: March 31, 2005, 07:25:03 pm »
I was going to mount the mobo and everything to the inside wall of the cab where the original JAMMA PCB was installed (NO PC CASE)
Do you guys see any problem with that?
SOAPboy
  • ..::GeeK::..
« Reply #14 on: March 31, 2005, 07:30:11 pm »
nope.. mines kinda like that..
just throw a fan or two blowing across everything and have a fan or two pulling said air out..
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #15 on: March 31, 2005, 09:07:06 pm »
Ditto for my cocktail unit.
Shep
  • Last login:January 06, 2006, 06:05:15 am
« Reply #16 on: April 01, 2005, 08:39:24 am »
Worked for me... also, don't rush to add extra cabinet fans - I've been running temperature logging software on my jamma->mame cab (which has an uncased motherboard) for the last fortnight, and discovered that the CPU (Sempron 2400) runs at a steady 43C, using no cabinet cooling other than the original (passive) convection vents.
Felix T Cat
  • Last login:September 08, 2020, 08:48:29 am
« Reply #17 on: April 01, 2005, 09:29:42 am »
For what it's worth you can get a 2.4g cell system from Dell with 512m ram and 80g hard drive for $284 plus tax.  It's a refurb but has the same 1 year warranty as new and they have free shipping on refurbs until 4-6-05
http://www1.us.dell.com/content/default.aspx?c=us&l=en&s=dfh&~ck=bt
Truecade
  • Last login:April 05, 2024, 07:00:29 pm
« Reply #18 on: April 01, 2005, 01:40:11 pm »
I was looking at this system for a cheap MAME box.  It might suit your needs, and comes with a 1 year warranty for $200.  The RAM is kind of skimpy, but 128 should be enough for MAME.
http://www.walmart.com/catalog/product.gsp?product_id=3380786
IntruderAlert
    • Intruder Alert
« Reply #19 on: April 01, 2005, 03:17:47 pm »
yeah.. quiet is better  ;D
cell system???
That link just takes me to the main page
Where can I find what you are talking about?
Thanks for the idea
I looked around in there for a while but everything in my price range at walmart.com is Sempron and 1.5ghz is a bit weak for CHD  imo
caffinefiend
  • Banned
  • Last login:September 12, 2005, 08:51:51 am
« Reply #20 on: April 01, 2005, 04:16:00 pm »
i have a 2.2 ghz celeron with 300 some megs of ram, 20 or 40 gb hd i forget, but i can fit a complete mame rom set for .69 along with mamewah and nes, sega, snes, genesis, tg16 full rom sets and emulators, i also have joypads that light up (the retrocons hooked to it and a steering wheel) anyway
2.2 ghz with the 300 some megs of ram runs everything, unlcuing the nba jam, mortal kombat (both suck anyway) and marvel vs capcom, metal slug, samsho5, and some sutff like that all full speed no frameskip... you should be just fine with a 2 ghz celeron pick up a full system on ebay for like 100 bucks
IntruderAlert
    • Intruder Alert
« Reply #21 on: April 01, 2005, 04:22:59 pm »
Thanks for the info dude
I was worried about going with celeron or sempron
do you ever get any glitches or lags or anything with the CHD games at all?
caffinefiend
  • Banned
« Reply #22 on: April 01, 2005, 04:50:31 pm »
chd is the only games i don't play, so i woulnd't know
it runs every other game full speed quick loading as well
elvis
  • penguin poker
    • StickFreaks
« Reply #23 on: April 01, 2005, 06:50:06 pm »
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« Reply #24 on: April 01, 2005, 06:59:27 pm »
The Athlon 64s are not a big jump over regular Athlons or Semprons for that matter in terms of speed with Mame.  My last MAME Cab had MSI Neo2 Platinum, Athlon64 3200+, 1 gig Corsair PC3200 value, and an ATI Radeon 9600 Pro 256meg AGP graphics card.  It was hardly (if any) faster on any games than my Athlon XP 2700+ system with 512 meg PC-2100 ram.
On a side note, hardly any CHD games are going to be playable on any system you can currently buy.  Killer Instinct 1 and 2 ran fine on my Athlon XP 2100+ system and basically the same on my Athlon 64s.  You will not be able to play games like Cruisin USA anytime soon on anything.
I would go with a Sempron 2600+ from newegg as your processor and an ASRock motherboard (if you insist on cheaping out a little :) ).  Like others said, Corsair Value ram and Kingston Value Ram is really cheap and WILL save you headaches found with cheap ram.
elvis
  • penguin poker
    • StickFreaks
« Reply #25 on: April 01, 2005, 09:57:33 pm »
Simply put, if you want to play more modern 3D games, use ZiNc, or go out and buy a Playstation/Xbox/whatever console.
MAME is about retro gaming.  For most of us, that means games that are 15+ years old that aren't around any more.  Not 3-4 years old, that can still be bought on store shelves.
Felix T Cat
« Reply #26 on: April 02, 2005, 08:18:07 am »
Go here:
http://www1.us.dell.com/content/default.aspx?c=us&l=en&s=dfh&cs=22
Click on Desktops
On the next screen where it say's "View Current Inventory" select Dimension Desktops
Then click on the price colum to sort by price.
IntruderAlert
    • Intruder Alert
« Reply #27 on: April 04, 2005, 03:02:02 pm »
MAME is about whatever games the MAME developers decide to work on
and I just want to be able to run them
Zeosstud
  • Last login:January 20, 2026, 05:52:04 pm
« Reply #28 on: April 04, 2005, 03:43:15 pm »
A Celeron 2.0Ghz runs Simpsons Bowling like crap, almost unplayable.  A true 2.4Ghz P4 runs Simpsons Bowling just fine in a system running windows XP Pro SP2 and 128 Megs of Ram,  I know this for a fact.  Almost none of the chd games run anywhere near playable anyway on ANY system.  I am not an expert, but I can confirm my above statement to be fact.
Rodney
IntruderAlert
    • Intruder Alert
« Reply #29 on: April 04, 2005, 04:57:19 pm »
Ok guys,
Thanks for all of the input.
I guess I'll need at least 2ghz to run the latest games and I shouldn't expect to run the CHD games very well or at all even with 3ghz or higher..  at least for now..
I'm looking forward to seeing how well M3talHead's 3ghz Athlon 64 system works for him
I think I'll hold off a bit longer on my purchase until he lets us know what he's able to run with it
CPickler
  • Last login:August 20, 2006, 02:37:14 am
    • CPU Studios
« Reply #30 on: April 04, 2005, 07:35:16 pm »
This makes me feel inferior.
I am running a P3 for my MAME system.  It's an old box I had lying around that used to be the music server for my fraternity.
I thought that most MAME games would run on a P3 with 128 MB RAM quite well.
Am I wrong?
paigeoliver
  • Awesome face!
« Reply #31 on: April 05, 2005, 03:59:03 am »
Am I wrong?
No, you aren't wrong. A 128MB P3 with the proper mame version (somewhere around .70 would be correct for a P3), will run roughly 98 percent of the games in Mame full speed.
The problem is that people won't stop talking about that other 2 percent. Half of that other 2 percent won't run on ANYTHING. Of the remaining ones roughly 75 percent require specialty analog controllers that most people won't have.
The list of games that need big hardware is pitifully short, and almost ALL of them are analog games. In basically EVERY case you gain more games by investing in more controller types than you do by investing in a faster computer.
Invest in a spinner, a true analog joystick, a trackball, even those little analog SNAP joysticks for the sports games, rotary joysticks, 4-way joystics, or a steering wheel. Each and every one of those controls enables more games than a faster processor does.
« Last Edit: April 05, 2005, 04:01:29 am by paigeoliver »
SOAPboy
  • ..::GeeK::..
« Reply #32 on: April 05, 2005, 05:13:09 am »
paigeoliver
  • Awesome face!
« Reply #33 on: April 05, 2005, 05:31:22 am »
Am I wrong?
So, What exactly does it take to get Killer Instinct 1 and 2 running at 95%-100% speed..
Other than blitz, those are the only ones i know of people trying to get running right.. oh well maybe street figher 3 or whatever..
Who knows, I never even bothered trying them. I already have 90,000 other games I don't have time to play, so I am certainly not going to start sweating over a few non-unique titles.
I have always figured that eventually the computer in my main cabinet will crap out. When it does then the replacement computer will certainly play all those games that everyone today is struggling with. I waited for STUN Runner, I'll wait for those.  The hardware will catch up, the hardware will always catch up.
CPickler
    • CPU Studios
« Reply #34 on: April 05, 2005, 05:44:53 am »
good mantra
IntruderAlert
    • Intruder Alert
« Reply #35 on: April 05, 2005, 08:36:29 am »
Am I wrong?
So what about the people who's computer has already crapped out?
pointdablame
« Reply #36 on: April 05, 2005, 04:24:43 pm »
You still don't need a NEW system.  If you're system craps out (or has) maybe you could take your current main computer and use that for your MAME system... and upgrade your main computer.
Or an even cheaper thing to do is just buy a used system or parts that are slightly out of date.  Yes you could spend $150 on an Athlon64, but you could get a nice Socket A motherboard, a 1800-2100 Athlon XP, and 512 of ram for that same $150 (or less).  Or you could very easily find a complete used computer in that same price range.
I love building computers, and if you have the cash.. go for it.  But I do agree with paige to an extent... it's definitely not necessary
« Last Edit: April 05, 2005, 04:29:56 pm by pointdablame »
Nocturnaloner
  • Last login:May 05, 2016, 12:39:53 pm
  • AARRRRcade!
« Reply #37 on: April 05, 2005, 05:43:50 pm »
I guess there's always sort of a conflict between those who feel that MAME is only for the classics, versus those who want every game to run smoothly.  Gross generalization, but you get the point.
I just bought an upgrade kit, and I "settled" for an AthlonXP 3200+ (up from an Athlon 1.33ghz), even though $25 more would've gotten me into an A64, because I set a spending limit and stuck to it.  I'm sure it'll play Area 51 though, and I'm also going to check out Daphne and Zinc.
pointdablame
« Reply #38 on: April 05, 2005, 07:04:49 pm »
see but that's the thing.. .you CAN'T play ever game.  I don't care what system you have.. you just can't. The debate is really about those who DEMAND to be able to play as many games as possible even if a $2000 computer can only play a dozen or so more games than a $300 computer.  I'm not directing that directly at you... I know you were generalizing like you said.. but the point still stands
CHD games and a rare handful of games that take a lot of PC power are the only things you add.  Now if you plan on doing more than MAME, I can see the point in it.. but if you are strictly MAME only... it really is overkill
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #39 on: April 05, 2005, 07:24:11 pm »
Another thing to keep in mind is that performance is going to change with each new release ... games that you might be gearing your system towards today might be slower or even unplayable in the a future (hence, so many people locking in on particular versions).
It's a moving target and the target doesn't always move in the direction you might think.
Cheers,
JAKD
Working: Not Enough
Projects: Too Many
Progress: None
