Author Topic: Wiring "Shift" function keys w/I-Pac  (Read 1284 times)
mac622
  • Last login:December 23, 2011, 01:21:29 pm
« on: March 31, 2005, 03:00:12 pm »
I'm having a bit of a senior moment and can't quite figure out the correct way to wire dedicated "shift" function buttons/switches (tilde, Esc, Pause, etc.) on a CP.
For example, to have a dedicated "Pause" button/switch would you split the wire coming from the NO terminal on the microswitch and connect one wire to the "Player 1" terminal on the I-Pac and other to the "1 Down" terminal?
My apologies for asking such a rudimentary question but the answer is eluding me at the moment.  ???
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Wiring "Shift" function keys w/I-Pac
« Reply #1 on: March 31, 2005, 03:01:06 pm »
If you want a dedicated PAUSE button, you wire the button up to INPUT 8 or something, and then program your ipac so button 8 is pause.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: March 31, 2005, 03:35:23 pm »
  The same deal if you want a dedicated i-pac shift key.. just wire it to any imput you don't normally use (like P1B8) and set it up in the WinIPAC utility that that key is the shift key and nothing esle.
-sab
cholin
    • Nilok Productions
« Reply #3 on: March 31, 2005, 03:37:32 pm »
Ahh, but he wants dedicated shift FUNCTIONS, not the key itself.  Otherwise, yeah youre right.
I think for the GPwiz or whatever its called, theres a cable he sells that splits one button into 2 inputs so you can use shift functions, but its not needed with an IPAC
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: March 31, 2005, 03:42:42 pm »
mac622
« Reply #5 on: March 31, 2005, 04:18:08 pm »
Awesome...Thanks for the help!
