Author Topic: Mounting a trackball in 3/4" MDF  (Read 2456 times)
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« on: November 14, 2002, 09:44:28 pm »
Hey guys,
Here's the situation.  I'm trying to mount a 3" imperial trackball into 3/4 MDF.  The trackball housing is about 8 inches wide, and shaped like a football if you look at it from the top.  How can I mount this in MDF?  Are the trakball mounting kits big enough (wider than 8 inches) to cut out a square that will fit the whole "footall shaped casing into it?
any help is appreciated!
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Mounting a trackball in 3/4" MDF
« Reply #1 on: November 14, 2002, 10:11:50 pm »
Hey guys,
I just recently mounted mine in 3/4" plywood, and I used a mounting plate... the one with squareholes andyou supply yer own carriabge bolts...
I cut the hole roughly in the shape of the football...  In the upper right and lower left corner it's a little tight - i.e.  there's not a lot of wood between the outer bolts and the hole the trackball housing is in... (i know..  a pic would be better sorry)...    I used the drill bit for making button holes 1 1/8th inch hole saw bit... to "Start" the cut and then just dropped my jigsaw in and followed my  traced outline as best I could...
does that help?   I imagine if you make your square big enough to drop the tball housing in but small enough to not have the mounting bracket fall in/have wood to screw in the corners...
*Shrug(
rampy
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: November 14, 2002, 10:25:00 pm »
what are you measure from to make it 8" wide?  I thought it was the standard 3" housing size so it can fit in machines with 3" trackball mounts:)
My wico and Happ 3" trackballs are about 7" wide.  The trackball plate is 7.5" wide.
even looking at the picture
http://www.gatorcade.com/imperial.html
it looks like a normal trackball.  you aren't measuring from point to point, are you?  the sides are the flat sides.  point to point is a diagnal on the trackball.
wee beastie
« Reply #3 on: November 14, 2002, 11:23:01 pm »
rampy,
yes, thanks for the help.  I guess I'll have to get a mounting plate.  Did you get it from bobroberts.com or happs?
When I measured 8 wide, I meant from one end of the "football" to the other.  Turns out the "football" doesn't mount horizontally like I thought, it's on a diagonal.  So the football more resembles a square with opposite corners rounded.  And 8 inches is the diagonal measurement
SirPoonga
  • Puck'em Up
« Reply #4 on: November 14, 2002, 11:46:47 pm »
I figured that's what you did.  I am going to get the screwless mounting plate from happs someime, I don't like the screwheads in the way.
rampy
  • *shrug*
« Reply #5 on: November 15, 2002, 11:22:05 am »
rampy,
I went with happs as I need some other misc stuff that got me over the 25 buck limit... but the one bobroberts sells will work as well and he doesn't have a minimum order.
rampy
