Author Topic: Soldering Iron  (Read 1227 times)
Franco
Soldering Iron
« on: March 30, 2005, 01:25:27 pm »
Right its about time I bought a soldering iron as I need to hack some N64 ports.
As always, ebay is worth a look for such purchases.
A quick search brought up this:-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=28057&item=4368245751&rd=1
Do you think it will be decent enough? Bear in mind its only once in a blue moon I will need to do some soldering. Or is it worth spending a little more and getting a higher quality one?
Im after a iron, stand and desoldering pump.
Any advice would be great!
bowza
  • Last login:July 08, 2005, 03:04:35 pm
Re: Soldering Iron
« Reply #1 on: March 30, 2005, 01:44:43 pm »
Given that you are asking the question I take it you have not done much soldering / de soldering.
That will be fine for most wire jobs.
I would not like to use it on ic components etc
But yes it will do for those once in a blue moon jobs.
Regards
Bowza
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Soldering Iron
« Reply #2 on: March 30, 2005, 01:58:07 pm »
I still use the cheap $7 Radio Shack iron I bought 10 years ago.
NO MORE!!
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Soldering Iron
« Reply #3 on: March 30, 2005, 03:11:34 pm »
Yeah Im gonna have to say go Radioshack if you have it.  I don't support them at all, but if you can just drive there and pick one up for <10 bucks, then its no big deal where you get it.  Look for ~15watts because those were made for ICs and electronics.  Higher wattages irons (and guns) are made more for connecting metal.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Soldering Iron
« Reply #4 on: March 30, 2005, 03:32:51 pm »
If you're in the UK it'll be hard to find a RadioShack. Find your nearest Maplins Electronics and take a look at them. You can pick up a good quality soldering kit for 20squid. That one on eBay is most likely junk.
Stingray
Re: Soldering Iron
« Reply #5 on: March 30, 2005, 03:41:49 pm »
Me too.
-S
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
Re: Soldering Iron
« Reply #6 on: March 30, 2005, 06:40:45 pm »
Looking at that soldering iron, the tip looks sort of big. Avoid getting irons with big tips. They are a pain to properly solder with.
I love the life I lead. I wish I could afford it.
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
Re: Soldering Iron
« Reply #7 on: April 02, 2005, 08:17:38 am »
That iron will do fine for jobs with bigger pieces.
If you want to solder fine wires and components(resistors, caps, ...), you'll need something with a fine tip and less heat than 30 watts. Maybe 25, preferably 20.
An ounce of image is worth a pound of performance.
Craig
Re: Soldering Iron
« Reply #8 on: April 02, 2005, 08:44:02 am »
I should also add that buying a good brand temp controlled one is a good idea too. It would likely last you the rest of your life if you don't use it every day ;-)
