Author Topic: Software to draw plans ?  (Read 2877 times)
Pipo
  • Last login:May 05, 2015, 09:15:48 am
« on: November 13, 2002, 05:31:41 am »
Hello
What software can I use to draw plans of my Cab ?
I'd like to draw parts, assemble them and be able to change
their size to do some tests
Have any soft for me ?
Or if you did plans what soft did you use
Oh, and btw, I have to use cm not inches ;-)
Thank you
mravett
  • Last login:April 17, 2014, 10:14:43 pm
  • I'm not a llama!!
Re:Software to draw plans ?
« Reply #1 on: November 13, 2002, 10:03:31 am »
A lot of people use Visio.  It's relatively easy to use and you can easily switch from inches to centimeters.  However, it's only 2-d so you can't exactly "assemble" your pieces in 3d.
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #2 on: November 13, 2002, 12:29:12 pm »
I do visio for things like Control Panel layouts, etc.  It's not a very good 3-d designer unfortunately, you typically need some sort of CAD program for that.  If you can't afford Visio though, this is a really good freeware program...
http://www.t4000.freeserve.co.uk/netpad.htm
Good Luck!
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #3 on: November 14, 2002, 01:39:15 pm »
Hello
The concensus among people who draw plans for a living (architects, planners, etc.) is that if you're only going to do it once, its faster to draw with a pen.
It's only when you start to need to do lot's of changes that software has an advantage, but that's only after you have come down the big learning curves.
I use Adobe Illustrator, second only to my pencil.
Bob
