August 27, 2025, 10:39:59 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Main Forum
How to make SQUARE holes for carriage bolts
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: How to make SQUARE holes for carriage bolts (Read 13667 times)
liche
Trade Count:
0
Full Member
Offline
Last login:November 13, 2007, 08:05:18 am
This is my BOOMSTICK!
on:
November 11, 2002, 07:40:10 am »
Without spending $200 for an expensive punch, what is the best way to make those square holes on my control panel (1/16" steel) to hold the carriage bolts?
Any help appreciated.
Logged
Lilwolf
Trade Count:
+1
Full Member
Offline
Last login:July 31, 2022, 10:26:34 pm
Re:How to make SQUARE holes for carriage bolts
Reply #1 on:
November 11, 2002, 09:11:01 am »
predrill a whole. then put the bold in and tighten. It will make it for you. At least that is what I did.
Logged
ErikRuud
Trade Count:
+1
Full Member
Offline
Last login:March 05, 2021, 10:20:27 am
I'll build a cab for only 99.99.99!!!
Reply #2 on:
November 11, 2002, 09:44:57 am »
Lil Wolf, that worked for a steel control panel???
I would drill a hole, and then use a square file.
Logged
Real Life. Still a poor substitute for video games!
American Laser Games Wrapper
O2em Rom Utility
MameFan
Guest
Trade Count:
0
Reply #3 on:
November 11, 2002, 10:29:00 am »
Use a triangular file. You can get them for under $3 at the hardware store. You can usually get a carton of 10 different files, rasps, etc. (square, round, triangular, flat) for $10 or so too.
Logged
liche
Trade Count:
0
Full Member
Offline
Reply #4 on:
November 11, 2002, 11:24:18 am »
Do you know what size pilot hole (prior to filing) is optimal for standard 3/16" carriage bolts. I say standard as I think this is the size most often used in control panels.
Thanks again
Logged
MameFan
Guest
Trade Count:
0
Reply #5 on:
November 11, 2002, 04:26:18 pm »
Make it exactly the width of the bolt, under the square... 3/16", then square out the corners. If you must go smaller wouldn't make it smaller than 1/8", as it would take too long to square out/more apt to mess up.
Logged
Darkstalker
Trade Count:
0
Full Member
Offline
Last login:June 27, 2010, 12:55:36 am
A legend in my spare time...
Reply #6 on:
November 11, 2002, 05:32:31 pm »
They actually make bits for cutting square holes...I know they exist for wood, but not sure about metal...
Logged
Still in the collecting parts and ideas phase of cabinet building.
eightbit
Trade Count:
0
Full Member
Offline
Last login:September 07, 2019, 07:38:11 pm
My cab is never done...
Reply #7 on:
November 11, 2002, 06:17:38 pm »
A mortise bit used for square holes in wood isn't going to help you with metal. I'd suggest the file route. If you have a lot of holes to do you could always bring it in somewhere.
Logged
Lilwolf
Trade Count:
+1
Full Member
Offline
Reply #8 on:
November 11, 2002, 09:24:07 pm »
Sorry, my example was for a wood control panel.
It would probably strip the bolts on a metal CP
Logged
spidermonkey
Trade Count:
0
Full Member
Offline
Last login:October 01, 2023, 04:15:59 am
Bombjack junkie
Reply #9 on:
November 11, 2002, 09:41:36 pm »
1/16" steel sounds awfully thin for a control panel but if thats what your using then just drill a 3/16" hole, tighten it and let the bolt do the work for you. 1/16" steel is barely thicker than sheet metal so the carriage bolts should have no problem pulling themselves through. If all your using is 1/16" steel then I would cover it with at least 3/16" or 1/14" lexan to give the panel some strenth or just use thicker steel. I used 3/16" steel for my cp and I was still able to just tighten the carriage bolts without having to square out the holes.
Logged
"Sinistar has bad breath"
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
