Author Topic: Trackball woes (SOLVED!)  (Read 1172 times)
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« on: March 13, 2005, 01:05:08 pm »
I just got a Happ 3" trackball that came with a PS/2 interface kit.
There's an external power connector that I believe is supposed to be used with a wall wart transformer.  I checked the specs on Happ's site, and it's 5VDC.
Is that power supply necessary?  I plugged the PS/2 cable into my PC's mouse port, and it's recognized as a PS/2 mouse.  The buttons work as the three mouse buttons.  However, the trackball doesn't move the mouse cursor at all.
I tried pulling 5V from a power supply connector, but that appears to have possibly blown the PS/2 port's fuse or something, because it doesn't show up as a mouse anymore.  I put it back on a different machine (PS/2 connection only), and it's recognized again (and the buttons work), but still no cursor movement.
When using PS/2 only, I only show 3.48VDC on the G/5V on the optical boards on the trackball.  That doesn't seem right.
I'm guessing that the ball needs a full 5VDC to operate properly, but for some reason, what I pulled from the PC power supply didn't jive with the rest of the stuff.
The guy who sold me the ball is looking around for the wall wart (it's a $25 product at Happ), but I'd like to get this working.
What are my options?  Get an Optipac and forego the PS/2 interface on this thing?  Should the 5V from the power supply have worked okay?  Are there any other voltages or anything I can check to see if this thing is working properly?
« Last Edit: March 14, 2005, 11:26:08 pm by bnelsontfs »
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Trackball woes
« Reply #1 on: March 13, 2005, 01:07:33 pm »
I know nothing about these but if it says it requires 5 volts, it should have worked without any problems!  Strange..
Captain_Dingo
Re: Trackball woes
« Reply #2 on: March 14, 2005, 11:25:21 pm »
I got it to work... And no blown fuse.
Pulled the 5V from a USB port, and threw a ringer in Shuuz.
