Author Topic: Universal Monitor/Tube mounting brackets - NO LONGER IN STOCK  (Read 15145 times)
1UP
  • Token Junkie
    • 1UPArcade
Re: New product: 27" Monitor mounting brackets
« Reply #40 on: March 22, 2005, 03:33:02 am »
Photos!
« Last Edit: March 22, 2005, 03:57:31 am by 1UP »
My other job...
lostwire
  • Last login:August 30, 2005, 02:04:45 pm
  • Moon Patrol. Boing Boing!
    • DVD In My Pants
« Reply #41 on: March 22, 2005, 10:06:15 am »
I'll be ordering a WG D9200 by mid-April & these brackets surely look like the perfect match for my project. Consider another pair sold once I purchase the monitor.
Ken Layton
  • Guru
  • Technician
« Reply #42 on: March 22, 2005, 10:58:03 am »
That picture shows a monitor with "universal" mounting frame installed on the bracket. What about those folks who have a monitor with standard horizontal "shelf" mounting. Shelf mount have the mounting holes spaced much diifferently than your mounting brackets. Are you selling two different brackets? Or are people with shelf mount out of luck?
If your bracket is only for mounting a universal frame monitor then your advertising should make that very clear.
whammoed
  • Last login:Today at 03:34:11 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #43 on: March 22, 2005, 11:05:04 am »
I didn't know any shelf mount 27" monitors existed.  All I have seen are the universal mounts.  Learn something every day I suppose.  Ken, does any manufacturer currently make a shelf mount 27"?  Could be a better option for some projects.
Ken Layton
  • Guru
  • Technician
« Reply #44 on: March 22, 2005, 11:29:00 am »
Wells makes the 27" in horiz mount by special order. There were some of the old k7000 series built in 27" AND in horiz mount!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #45 on: March 22, 2005, 02:25:17 pm »
I have updated the top post to clarify.
« Last Edit: April 02, 2005, 02:57:23 pm by 1UP »
My other job...
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #46 on: March 26, 2005, 04:56:09 pm »
BUMP---just ordered my set, money sent...
Southpaw
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #47 on: March 27, 2005, 09:09:12 pm »
Okay....I just pulled the TV I'm going to use out of its case to measure the mounting brackets.  I'm a little concerned about the brackets on my monitor not matching up correctly with your panels.   Can you tell me if this will be compatible with your brackets?  The inside width of my cab should be okay at 26 1/2" (I'll have to add some material between the sides panels and the brackets, of course), but I'm concerned about the space between the top and bottom mount on your brackets not matching up with the top and bottom mount for my monitor.  I've attached a diagram of a front-fiew of my decased tv-monitor.  Can you tell me if this will be compatible with your brackets?
(I suppose I could have PM'd you with this, but it seemed like a good excuse for a bump  :) )
Best Kid iPad Apps
1UP
  • Token Junkie
    • 1UPArcade
« Reply #48 on: March 27, 2005, 09:42:48 pm »
My other job...
southpaw13
  • Whatever!
« Reply #49 on: March 27, 2005, 09:53:00 pm »
Can I have mine as one peice.  I can always cut them if needed.  I think they would be stronger as a single unit.
Thanks,
Southpaw
1UP
  • Token Junkie
    • 1UPArcade
« Reply #50 on: March 27, 2005, 10:05:38 pm »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #51 on: March 27, 2005, 10:14:35 pm »
Actually, scratch that:  We'll cut a few in half for those with different mounting requirements!  :)
My other job...
shmokes
    • Jake Moses
« Reply #52 on: March 27, 2005, 11:28:55 pm »
This may be obvious to you already, but I thougt I'd mention it, just in case....simply cutting it in half will work for those who need them to be taller than they are, but will not work for people like me who need them to be shorter than they are.  They will actually need to have a section cut out of the middle, I guess.  Otherwise, the two pieces would overlap eachother.
« Last Edit: March 28, 2005, 12:14:46 am by shmokes »
Best Kid iPad Apps
1UP
  • Token Junkie
    • 1UPArcade
« Reply #53 on: March 27, 2005, 11:36:12 pm »
My other job...
namedos
  • Last login:July 16, 2025, 07:15:23 pm
« Reply #54 on: March 29, 2005, 04:24:39 pm »
Have these shipped yet?  When do you expect them on your website?  Thanks.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #55 on: March 29, 2005, 04:58:11 pm »
« Last Edit: March 29, 2005, 05:00:34 pm by 1UP »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #56 on: March 31, 2005, 03:39:48 am »
Pics and a few specs on the new 3-piece design:
The new design features two adjustable halves, with a third plate connecting the two together and providing extra screw locations.
« Last Edit: March 31, 2005, 03:43:33 am by 1UP »
My other job...
namedos
« Reply #57 on: March 31, 2005, 11:14:29 am »
Just placed my order.  I'll keep watching for a relase date.  Thanks.
shmokes
    • Jake Moses
« Reply #58 on: March 31, 2005, 10:18:26 pm »
You should make sure this product gets exposure in the Monitor/Video forum as well, in case any of those yahoos don't visit the main forum.
Best Kid iPad Apps
lostwire
    • DVD In My Pants
« Reply #59 on: April 01, 2005, 06:24:44 am »
Will the one piece brackets still be available?
1UP
  • Token Junkie
    • 1UPArcade
« Reply #60 on: April 01, 2005, 12:30:17 pm »
These will replace the one piece design.  With the sections securely bolted together, they serve the same function, and in fact, may be more secure when mounted due to the extra mounting holes.
My other job...
lostwire
    • DVD In My Pants
« Reply #61 on: April 01, 2005, 12:49:00 pm »
1UP
  • Token Junkie
    • 1UPArcade
« Reply #62 on: April 01, 2005, 02:15:19 pm »
To make a separate version that is only compatible with one size of monitor, would not sell as many, so would not be cost effective.
« Last Edit: April 01, 2005, 02:28:52 pm by 1UP »
My other job...
lostwire
    • DVD In My Pants
« Reply #63 on: April 01, 2005, 02:48:05 pm »
1UP
  • Token Junkie
    • 1UPArcade
« Reply #64 on: April 01, 2005, 02:59:38 pm »
My other job...
lostwire
    • DVD In My Pants
« Reply #65 on: April 01, 2005, 03:32:35 pm »
That sounds good, 1UP. Consider another pair sold.
namedos
« Reply #66 on: April 01, 2005, 03:37:36 pm »
1up, did you receive my payment via paypal?  Thanks.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #67 on: April 01, 2005, 04:02:36 pm »
My other job...
1UP
  • Token Junkie
    • 1UPArcade
Re: New product: Universal Monitor/Tube mounting brackets - UPDATED DESIGN
« Reply #68 on: April 12, 2005, 01:05:05 pm »
Just an update for all those who have ordered so far:  We have received most of the components for the brackets, we are now waiting on equipment and raw materials which are due to arrive late next week.  We will begin production as soon as everything arrives, so the brackets should start shipping in 10-14 days.
Thanks for your orders!
My other job...
depressd
  • Last login:April 04, 2019, 04:29:33 am
I just wanted to say thanks to 1UP for providing a great solution and product for mounting my monitor. I received mine yesterday and it looks like it will work perfectly.
namedos
I installed mine today and they work great.  Easy installation for my Betson 27" monitor.  Thanks 1Up for a good product that was easy to work with!
1UP
  • Token Junkie
    • 1UPArcade
Thanks for the feedback!  I hope you were able to figure out the locations for all 16 wood screws (8 of them go through the slots, into the holes behind the adjustment plate).  I just finished a manual today that should help in the future.
I am totally out of stock on my first 10 units!  Hopefully there will be enough interest to do a larger run.  Thanks for all the orders.
My other job...
AlanS17
    • AlanS17
You may wanna consider putting this (or at least linking to it) in the B/S/T forums. I would think some people would miss it here since they're not expecting to see it here.
It's news so it belongs here, but it's also sales and you might get more hits in B/S/T for it.
shmokes
    • Jake Moses
I just got my mounting brackets.  They look great and are very solid.  I'm considering taking them into a welder and having lips welded on to the front of the bottom brackets to hold some tinted glass.  If I do I'll take pictures to show how it works out.  Can anybody think of anything I should keep in mind when doing this?  I'd hate to have it welded on only to realize it should have been done differently or I needed a bigger lip or something.
Best Kid iPad Apps
MrSaLTy
  • Last login:August 10, 2025, 05:07:28 pm
  • nabisco reject
Welding can cause heat warping of the metal.  Its more likely the thinner the metal is.  Just be careful you don't want to ruin them.
1UP
  • Token Junkie
    • 1UPArcade
My other job...
Kremmit
  • - AHOTW -
  • Who the heck is that?
Don't weld- JB Weld!
Real welding may be a bit of overkill for a sheet of glass whose weight will not even be resting against the welds.  Why pay a welder?
1UP
  • Token Junkie
    • 1UPArcade
UPDATE: More now available!
I have 10 brand new sets, ready to ship.
« Last Edit: July 05, 2005, 04:51:40 pm by 1UP »
My other job...
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Hey 1UP, this should work for a standard 19" arcade monitor right?
I've been thinking about fixing my double dragon2.  The main problem with it is the monitor mount is cracked and broke.  The part on the cabinet the board slides in is busted and the board itself is cracked.  I know it's just a couple of pieces of wood that could easily be replaced.  However a metal solution would be more sturdy and that would never happen again.   It would just be a matter of figuring out where to mount the brackets so the monitor is in the same position as it should be (so the monitor lines up with the bezels and such).
1UP
  • Token Junkie
    • 1UPArcade
My other job...
