Author Topic: Wanting to use Serial Mad Catz Analog Pedals by themselves, need info  (Read 1150 times)
Projekt Produkt
  • Last login:September 29, 2015, 04:41:24 pm
  • I build custom controllers to your specs.
    • Projekt Produkt
I've got a set of serial port Mad Catz racing pedals.  I'm assuming they went with the Analog Mad Catz steering wheel.  I'd like to find a driver to make them work alone.  I've been all over the web looking for info and drivers for them and have come up dry.  Anyone using these pedals or have a driver for them?
Thanks everyone;
Kevin
Owner, Designer, Engineer, etc.  of Projekt Produkt .com
menace
Re: Wanting to use Serial Mad Catz Analog Pedals by themselves, need info
« Reply #1 on: February 16, 2005, 07:24:14 am »
you'll likley have to hack them to a joystick to get them to register properly--find an el-cheapo usb joystick and hack the pedal to the x and y pots respectively or if you have two sets--hack one set to x and the other to y
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
« Reply #2 on: February 16, 2005, 09:05:18 am »
I think that you could wire them through an AKI, and get them to work ???
