Author Topic: Need help choosing motherboard compatible with ArcadeVGA card.  (Read 3627 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
« on: February 15, 2005, 01:48:03 pm »
Well, I have my pc all loaded up with games and ready to go.  The
controller works great, the games work, Mame runs good (mame32 right now vs. .89)
My system is:
> Pentium 450 mghz
> 80 gig hard drive
> 192 megs of RAM
> Windows 98SE
Well, it appears the Arcade VGA card may not be compatible with the agp slot in my motherboard (per Andy) so I guess I need to buy a new motherboard, processor, Ram.  I'd like your help to pick something that will definately work with the Arcade VGA card.  I'd like to keep the price down and just upgrade to say a 1 GHZ machine.  Can you all recommend a motherboard, processor, and Ram from Newegg.com?
Thanks.
Wyluli
Re: Need help choosing motherboard compatible with ArcadeVGA card.
« Reply #1 on: February 17, 2005, 12:22:28 pm »
*bump
One last plea for ideas.
Thanks.
Lilwolf
« Reply #2 on: February 17, 2005, 12:34:45 pm »
It should be compatible with anything current.
decide on what type of processor your looking for and go from there.  You probably want to ask which chipset is it compatible with....  Usually makes more of a difference then the brand.   Go with a standard one and you shouldn't have any problems.... Don't go with a brand spankin new motherboard just produced... takes about 3 - 6 months to get all the bios updates to work well... but since you are looking 1ghz range... you probably wont deal with this.
btw, pick your price... Then start looking from there.  Price / performance is probably worth looking into... go down to those prices...and you can double the speed of a machine for 20 bucks or less... and get new boards that haven't been in storage for 3 years.
Paul Olson
    • Paul's Arcade
« Reply #3 on: February 17, 2005, 01:15:58 pm »
Look at Fry's, you should be able to pick up a MB/CPU combo for $50-$70. For that price you should get an Athlon XP 2000 or better.  Another $70 at Newegg for 512MB of PC3200, and you are all set.
The Frys combos have lower end MBs, but they work fine.  I have 2 systems running them now and they are very stable.
Paul
Wyluli
« Reply #4 on: February 17, 2005, 01:25:36 pm »
How about this:  (http://www.newegg.com)
Intel Celeron(Pentium 4 based) 1.8 GHz 400MHz FSB, 128K Cache - Retail
Model# BX80532RC1800B
Item # N82E16819112172
PRICE $57
FOXCONN "655A01-FX-6LRS" SiS655FX Chipset Motherboard for Intel Socket 478 CPU -RETAIL
Model# 655A01-FX-6LRS
Item # N82E16813186011
PRICE $44
ASRock "P4V88 RAID" VIA PT880 Chipset Motherboard for Intel Socket 478 CPU -RETAIL
Model# P4V88 RAID
Item # N82E16813157034
Price: $47
Which MB would you get?  Will the processor work ok with these boards?  Is Celeron good enough for emulation?
Thanks.
P.S. what is fry's?  Is that a website, or a store in the UK or something?
Paul Olson
    • Paul's Arcade
« Reply #5 on: February 17, 2005, 04:39:11 pm »
Frys Electronics.  I don't know if they have them back east, they are everywhere on the west coast.  They joined with Outpost.com for their online store.  It is a seperate store, and doesn't usually have the same specials.  Sometimes they do, I bought a harddrive from outpost last month, and it was pretty much the same deal as the Frys B&M.
I would think an Athlon XP of similar speed would be a better option than the Celeron.  P4 and Athlon of the same speed would be pretty close in performance, but the athlon would be cheaper.
Paul
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: February 17, 2005, 07:06:42 pm »
What exactly was not compatible? Was it just the AGP speed?
NO MORE!!
ssjenkins
  • Last login:May 06, 2008, 01:08:32 pm
« Reply #7 on: February 17, 2005, 09:20:46 pm »
Well I've just been through this with Andy . I sent the first card back as I thought I was faulty . Turned out that both my IBM NetVista and Dell Dimension 8100 were not "compatible" with the ArcadeVGA (or viceversa) . The BIOS wouldn't pass the p.o.s.t . So I went down to my local DIY PC shop and bought a :
ASRock K7S41 mother board : 33 Euros
AMD Sempron 2200+ (1.5Ghz) : 47 Euros
256M RAM: 29 Euros
ATX 300W PSU :19 Euros
and a few other bits and pieces , fan , floppy etc .... for a grand total of 164 Euros . Tested and working fine with my (replacement) ArcadeVGA card .
Sammy
Born to lose .....
krick
  • Gotta have blue hair.
« Reply #8 on: February 18, 2005, 01:01:38 am »
Motherboards from ABIT and ASUS are very good.
I personally own the ABIT IS7-E and IS7-E2.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #9 on: February 18, 2005, 03:02:16 am »
The current ArcadeVGA batch are based on Radeon 9200 cards, and therefor are AGP4X/8X.
These certainly will not work in AGP1X boards, as the AGP port cannot output the correct voltage needed for the card (you actually risk damaging the board, your card, or both!).  I'm not 100% sure if they will work in AGP2X slots, but I doubt it.
Safest bet as mentioned is to buy a new board that definitely supports AGP4X or 8X for guaranteed compatability.
Wyluli
« Reply #10 on: February 18, 2005, 01:28:29 pm »
« Last Edit: February 18, 2005, 03:54:36 pm by Wyluli »
krick
« Reply #11 on: February 18, 2005, 01:49:49 pm »
You have to make sure that the processor you choose is compatible with the motherboard you've chosen.
In the case of the Abit IS7-E2, you need a Pentium 4  (or Celeron) socket 478 processor.  A pentium III won't work.
Check the details on the AMD setup to make sure what you've selected will work.
I always buy retail (boxed) processors because they come with good heatsink/fan units.
The savings you get from buying an OEM (non-boxed) processor is usually not enough to cover the cost of a good heatsink/fan unit.
Plus, retail boxed processors usually have 3 year warranties.  Bare processors have 1 year warranties at best.
Hantarex Polo 15KHz
Wyluli
« Reply #12 on: February 18, 2005, 04:05:08 pm »
Ok, I'm really trying here I swear.
« Last Edit: February 18, 2005, 04:08:07 pm by Wyluli »
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #13 on: February 18, 2005, 05:40:16 pm »
Surely any AGP 4x video card should be compatible with any AGP 4x compatible mobo? (ArcadeVGA is AGP 4x isn't it?)
