Author Topic: What's the wire for around the front of the screen?  (Read 1961 times)
SadGamerGeek
  • Last login:November 27, 2005, 06:23:54 pm
    • Sad Gamer Geek
« on: February 13, 2005, 02:06:17 pm »
I recently purchased a 21" CRT monitor on eBay for a good price, and I'm hoping to eventually use it for a cabinet I'm soon to build. It is an Eizo 21" - model Fexscan F77. I thought I might use it without the cover, so I removed the cover to see what it looked like "naked". I notice there is a wire that is attached to the inside of the front cover that connects to a two PCB type strips at the top and bottom of the screen. The wire does not terminate on anything. Maybe these pictures will make things clearer:
Does anyone know what these are for (degaussing?), and if removing them (by not using the front of the case) is likely to cause problems.
I hope this question isn't too stupid - my knowledge of monitors is extremely limited!
Cheers,
Richard
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: What's the wire for around the front of the screen?
« Reply #1 on: February 13, 2005, 03:06:29 pm »
Closer pics would help.
And are there any componets on the other sides of the boards?
Later,
dabone
SadGamerGeek
    • Sad Gamer Geek
« Reply #2 on: February 13, 2005, 03:51:03 pm »
I'll try to take some closer pics in soon, but there's not a lot to see. Nothing is connected to the other side of the PCB - it is completly blank.
Cheers,
Richard
SirPeale
  • Green Mountain Man
« Reply #3 on: February 13, 2005, 09:58:40 pm »
Def. not degauss.  Is there anything on the PCB?  LEDs, perhaps a microphone?
dabone
  • Time to work...
« Reply #4 on: February 13, 2005, 10:26:55 pm »
Maybe something to discharge the static from the screen on power on????
(Can't see why they would waste that much fiberglass for a led or mic board..)
Later,
dabone
SadGamerGeek
    • Sad Gamer Geek
« Reply #5 on: February 14, 2005, 03:49:28 pm »
There's absolutely nothing connected to the PCB - weird isn't it?
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« Reply #6 on: February 17, 2005, 09:55:12 am »
Check out this post.
The concensus was RF shield.
SadGamerGeek
    • Sad Gamer Geek
« Reply #7 on: February 17, 2005, 02:01:44 pm »
mmmPeanutButter  - excellent! Thanks very much for digging that post out. It looks very similar to what I have, so I'm sure it must be the same thing.
Cheers,
Richard
