Author Topic: metal stip around front of monitor??  (Read 1862 times)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« on: December 09, 2003, 06:32:05 pm »
I took apart my 21" Viewsonic monitor the other day to start the drawings and planning for my cabinet.  When I took off the bezel, I found a 'C'-shapes metal strip around the inside which was connected to a wire.
Is this part of the degaussing for the monitor?  If not, what is it?  I imagine that it has a purpose.
If I take the monitor out of the case for the cabinet, can I just put the metal strip between the tube and the custom wooden bezel, or is there a "science" to its placement?
thanks
Ken Layton
  • Guru
  • Technician
Re:metal stip around front of monitor??
« Reply #1 on: December 09, 2003, 06:44:29 pm »
Looks like it's a radio frequency shield to keep radio frequency interferance to a minimum as per FCC regulations. This is done so that the monitor meets USA requirements so that it can legally be sold and operated in this country.
MonitorGuru
« Reply #2 on: December 10, 2003, 09:22:08 am »
I concur... just an RF shield.  Don't bother attempting to reuse it in your cab.
BillyJack
  • Last login:August 17, 2025, 02:58:00 pm
  • Must...paint...cab...! Must...buy...marquee..!
« Reply #3 on: December 21, 2003, 10:30:21 pm »
Seriously?  I noticed them on my Mag monitor but just laid them out of the way... then i noticed my monitor image would bounce every now and then and i'd smell something odd...  so i taped the strips to the top and bottom of the tube and it stopped.  I concluded (along with a few on this and other message boards) that they were used as static collectors.  Of course, mine had 2 wires running from the strips to somewhere else on the monitor.
Oh well, maybe i don't need them after all.
« Last Edit: December 21, 2003, 10:31:26 pm by BillyJack »
Now I've had my head in an elephant, a hippo, and a giant sloth.
-Homer
