Author Topic: button labels??  (Read 1157 times)
wrench
  • Last login:August 02, 2024, 03:16:38 pm
  • Another project I couldn't say no to
button labels??
« on: January 20, 2005, 10:28:51 am »
Has anyone found a good way to label or mark the buttons on the cp,most buttons don't need marked but I'm planning to have a couple pause,quit ect buttons on the cp and would like to clearly label them.I'm looking for something that will hold up under use.Anyone know if the button protectors Happ sells are hard plastic or soft rubber covers and if they work only on happ buttons or will they fit others like the ultimarc buttons?
oldsage
  • Last login:December 19, 2005, 09:11:47 pm
  • Does SHMIGRUB ring any bells??
Re: button labels??
« Reply #1 on: January 20, 2005, 10:39:47 am »
I think those are the exact same pushbuttons, but i might be wrong...
Also, are you talking about sticking labels on top of the buttons, or next to them?
If next to them, then just place the labels on the CPO...
If you want the labels on top, i think i saw something at happs for "normal" pushbuttons... Otherwise you could just use "label printer paper" (or whatever they're called)...
But that wouldn't look that good... :(
I had a cool sig once... But it had to go because of *someone*... You know who you are!
crashwg
Re: button labels??
« Reply #2 on: January 20, 2005, 11:02:04 am »
Custom labeled buttons in 3 easy steps!
1. put a piece of scotch tape on the button
2. cut out desired patern (hint, you can print on scotch tape)
3. spray with a product called vinyl dye available at most auto supply stores and even wal*mart!
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Tiger-Heli
    • Tiger-Heli
Re: button labels??
« Reply #3 on: January 20, 2005, 11:13:30 am »
I just made Quit a red button (like Stop) and Pause an orange button (almost Stop).  And Coin Green buttons (Go or the color of money).  Worked for me.
whammoed
  • Last login:July 29, 2025, 11:05:33 am
  • Crack don't smoke itself
    • NiceMite
Re: button labels??
« Reply #4 on: January 20, 2005, 11:24:42 am »
Use illuminated pushbuttons.
wrench
Re: button labels??
« Reply #5 on: January 20, 2005, 08:00:09 pm »
Thanks whammoed,thats the best sounding recomendation I've gotten,I wanted something that  looked good and would hold up under use,that looks like the solution.
Jakobud
  • Last login:June 30, 2025, 02:20:39 pm
Re: button labels??
« Reply #6 on: January 20, 2005, 08:40:16 pm »
Why don't you just make an control panel overlay graphic and put it under some lexan?  Take a look at my website for an example with my cabinet.
