Author Topic: Coin mech wiring  (Read 9444 times)
Reaper
  • Last login:June 24, 2006, 09:11:10 am
  • I want to finish my arcade cabinet!
Coin mech wiring
« on: January 12, 2005, 02:39:49 pm »
Hi guys,
I won a coin mech on ebay & am trying to get it to work, unfortunatley I can find almost nothing about either parts of it & was wondering if any of you guys either know of a good place to look or actually have one, I have:
Mars Electronics MS 111 TS 5 Coin Validator
Philip Shefras Spares "blue board" that I assume is the bit that sends out the signals to the game/pc
All I have been able to find out is the dip switch settings for the blue board :(
Anyone able to help?
Ken Layton
  • Guru
  • Technician
Re: Coin mech wiring
« Reply #1 on: January 12, 2005, 06:08:51 pm »
You have a Mars electronic coin chute replacing the standard mechanical coin mechs & coin switch. Visit the manufacturers website www.meiglobal.com
Reaper
« Reply #2 on: January 13, 2005, 02:32:22 am »
cheers, I will have a look at that, it is ste Shefras board that is the main problem though as I assume that it is the bit I will need to connect to the pc.
yaniktheyak
  • Last login:July 26, 2012, 06:22:42 pm
« Reply #3 on: January 13, 2005, 03:51:20 pm »
Hi
Sounds like you have a similar setup to me.
I want to connect mine to a JPac, but unfortunately the coin mech runs at 12v, which is too high for the J-Pac - so I've left it disconnected.
My friend reckons a simple transistor circuit could be my answer?
I have some instructions for the board but they are on paper at the moment.
If no one else replies I'll try and scan them on Monday.
Stingray
« Reply #4 on: January 13, 2005, 03:57:15 pm »
Why don't you just pull 12 volts off an unused drive connector on your computer's power supply?
-S
Reaper
« Reply #5 on: January 14, 2005, 04:09:59 am »
Yeah, use a drive power connector, the yellow lead is the 12v (incase you didnt know :) ) & either of the black leads for the ground.
If you could scan it that would be great! - The guy I bought it from has faxed me a sheet, but most of it is un read-able :(
Reaper
« Reply #6 on: January 15, 2005, 11:53:32 am »
Right, I have it working now & want to know, can I connect both credit buttons of the ipac to the same button?
yaniktheyak
« Reply #7 on: January 16, 2005, 06:01:44 am »
I would have thought that would put a credit in P1 and P2 (simultaneously) each time one credit was added to the coin mech??
Like pushing 2 buttons at the same time? Dunno for sure though.
Is the 12v issue only an issue of powering the coin mech (from the JAMMA connector (j-pac)) -
I have a PSU in my cab with 12v which is wired to the JAMMA connector at the 12v pins - I assume the J-pac has no connections at the 12v and 5v pins - so no damage can be caused.
My concern was that the Coin1 pin on the JAMMA had 12v on it - the J-Pac instructions implied a 12v pulse from the coin mech. I see that the J-Pac treats the Coin1 and Coin2 just like ordinary buttons - (active low).
Do coin mechs (even 12v ones) make Coin1 go active low?
yaniktheyak
« Reply #8 on: January 17, 2005, 04:58:06 am »
Here are the scans of my instruction sheets.
Hope they are easier to read than your faxed copy.
How's it going connecting it up?
Cheers
Ian
Reaper
« Reply #9 on: January 17, 2005, 05:21:31 am »
Thanks for that, I got it working over the weekend in the end, but it will be good to have a copy for future reference :)
yaniktheyak
« Reply #10 on: January 21, 2005, 06:27:02 am »
Hi me again :)
I was just wondering - you use your coin mech with a J-Pac (or I-Pac).
The output to Coin 1 (or Coin 2) from the coin mech, is just an Open connection (no volts) which connects to Ground when a coin is inserted - is that right?
So the 12volts I'm worrying about frying the J-Pac with, never actually gets involved with the 'Coin 1' connection. The 12volts is purely to power the coin mech. - Is that right?
Sorry to sound a bit dim - but I just want a little more confidence before I plug the coin mech into my J-Pac 'Coin 1' pin. The J-Pac instructions are a bit scarey when it comes to coin mechs.
Thanks in advance
Ian
Reaper
« Reply #11 on: January 21, 2005, 09:30:56 am »
I have mine plugged into an ipac-2 & it is currently connected to both coin inputs 1 & 2. As far as I know, all it does is when a coin is inserted into the coin mech, the mech sends a signal to the shefras board (which, I think only has the 12v supply to power its self & the actual coin mech) the shefras board then sends power to a soleniod (sp?) which is just a powered switch.
So once the coin is inserted, assuming the mech is set to give say 6 credits for in my case
yaniktheyak
« Reply #12 on: January 21, 2005, 11:06:54 am »
I see.
So there's no volts on the 'Coin 1' because it is effectively an open switch to ground.
OK
I'll plug mine in and see if it works  :)
Cheers
Ian
Reaper
« Reply #13 on: January 21, 2005, 03:25:38 pm »
good luck :)
let us know how you get on!
neo_virus
  • Last login:January 18, 2007, 05:32:17 pm
« Reply #14 on: February 03, 2005, 09:47:29 am »
Hi,  currently have a Mars ME126 coin mech, right now though I don't have a credit board and will be planning on getting one of the credit boards from Swallow Amusements. On their site they have listed credit boards for MS/ME series as
yaniktheyak
« Reply #15 on: March 04, 2005, 07:31:12 am »
I plugged mine in and it works nicely.
It was set to 20p per play, with bonuses on 50p and
