Author Topic: removing brand stamp from lumber for staining  (Read 886 times)
WonderMellon
  • Last login:February 10, 2019, 12:41:23 am
« on: January 11, 2005, 10:00:54 am »
For those of you who have done stained cabinets.  I have purchased a few wood pieces from Home Depot.  The big plywood sheets do not have any marks on them, but the smaller pieces are stamped with the lumber company and type of wood.  It looks like some kind of paint or ink stamp.  How do you remove this for staining?
I was told that rubbing alchohol and  #0 steel wool might take it off, but that does not remove it all.  Any suggestions?
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
Re: removing brand stamp from lumber for staining
« Reply #1 on: January 11, 2005, 10:09:50 am »
sanding it out will work...and will leave you with a nice smooth surface.  If you sand it, do the whole board, not just the spot...or it will take the stain differently.
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #2 on: January 11, 2005, 11:15:34 am »
Don't they usually only stamp one side of the board? If thats the case you could use the other side.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: January 11, 2005, 08:42:52 pm »
Also, if you're using a water based stain / poly, that steel wool may shed fibers in use and potentially rust over time, ruining your finish later on down the road.
Sand the whole board down through progressively finer grits and you'll be good.
WonderMellon
« Reply #4 on: January 11, 2005, 09:14:51 pm »
I was going to bring out the sander anyway, but it looks like it will solve the stamp problem as well.
