Author Topic: Spinners designed for Mame, used for Atari paddle games  (Read 2178 times)
jcroach
  • Last login:March 01, 2012, 09:36:56 am
« on: January 10, 2005, 12:43:07 pm »
I'm not sure if this is the right forum for this.
« Last Edit: January 10, 2005, 12:46:01 pm by jcroach »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Spinners designed for Mame, used for Atari paddle games
« Reply #1 on: January 10, 2005, 01:16:55 pm »
It would work ok.  Though the paddles are pot based based like you know.
I haven;t used a 2600 emu.  It partly involves what the emu can handle.  If it can handle mouse and joystick input than oyu can do whatever you want.
For modding actual controllers you will need to hacke the pots into either the gameport, or if you want usb into a pc joystick.
jcroach
« Reply #2 on: January 10, 2005, 01:33:52 pm »
I'd love to hack them into a USB joystick.  Anything in particular that I should look for when buying a joystick to hack?
Oh, and I believe Z26 (an atari2600 emulator) will allow mouse input for paddles.  I'm not sure how good the gameplay is however.
« Reply #3 on: January 10, 2005, 01:51:45 pm »
You could also just buy a 100k pot and interface to the gameport as shown here:
http://www.gunpowder.freeserve.co.uk/wheels/wiring.htm
...then get a GamePort > USB adaptor.
Possibly just buying a USB joystick would be cheaper, I'm not sure.
jcroach
« Reply #4 on: January 10, 2005, 02:07:33 pm »
Why an 100k pot?
jcroach
« Reply #5 on: January 10, 2005, 02:18:47 pm »
Could I use the Dual Strike USB hack? I think the atari paddles and the Dual Strike both use 5k pots.
http://1uparcade.robandmitsue.com/projects-dualstrike.html
Oddfeld
  • Last login:October 26, 2024, 04:46:39 pm
  • I was Jeff Minter's llama!
« Reply #6 on: January 10, 2005, 02:29:42 pm »
If you can't find original Atari 2600 paddles in decent condition, you may be interested to know that Jakk's released a paddle version of their TV game units (those 'play umpteen old Atari games all built into this retro-style joystick that you plug into your TV' things). Dunno how easily hackable they are...
http://gear.ign.com/articles/526/526896p1.html
jcroach
« Reply #7 on: January 10, 2005, 02:51:28 pm »
Thanks for the suggestion.  I actually got one of these for Christmas.  It made me want to play Kaboom! again with a real paddle.  Kaboom! was an activision game and the Jakk's system only has Atari software on it.  I might opwn mine up and see how it works though.
I may end up going with the Dual Strike hack though.
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: January 10, 2005, 05:27:21 pm »
I would think so . . .
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« Reply #9 on: January 10, 2005, 05:35:49 pm »
« Reply #10 on: January 10, 2005, 07:26:57 pm »
Why an 100k pot?
Because 100k pots can be interfaced straight to the gameport (5k ones can't).  Not sure how close a 100k pot + cable + a gameport plug + gameport > USB adaptor would be cost-wise compared toe a Dual Strike, probably a bit cheaper I would think.
