Author Topic: wico mounting  (Read 1249 times)
muell67
wico mounting
« on: December 16, 2004, 09:01:07 pm »
well I just got a wico joystick the one 8 way with micro swithces and I was just wondering what type of material these are typically mounted to should I go 1/2" or 1/4" or maybe use some type of metal mounting plate. I mounted my p360 in 1/2" but they arent as short as the wico. and im woried a 1/4" would be to thin. Also when I say 1/2" or 1/4" Im talking about after I rout out my 3/4" mdf control panel. thanks
NoOne=NBA=
Re: wico mounting
« Reply #1 on: December 16, 2004, 09:09:51 pm »
I mounted mine straight to the bottom of the 3/4" plywood.
I wouldn't rout more than 3/8" deep into the MDF.
If you want them even taller than that, I'd go with a mounting plate.
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
Re: wico mounting
« Reply #2 on: December 16, 2004, 09:38:50 pm »
Joystick mounting plate?  I was hoping to route out 1/2" plywood
to a 1/4".  Any others advise against it?
muell67
Re: wico mounting
« Reply #3 on: December 16, 2004, 10:01:10 pm »
how where thes mounted by the factory in original games?
Rocky
Re: wico mounting
« Reply #4 on: December 17, 2004, 09:29:54 am »
Original mounting was with 3/8" carriage bolts. They were for security, so they could only be taken off from the under side of the CP.
A lot of the games used metal panels, but some used wood. They will work with either. You can get varying lengths of carriage bolts.
Rocky
leafblade
Re: wico mounting
« Reply #5 on: December 24, 2004, 03:44:06 pm »
Are these for mounting wico's with the shorter ball handle shafts?
muell67
Re: wico mounting
« Reply #6 on: December 25, 2004, 12:59:37 am »
the joystick I have has a short ball handle shaft and I just mounted it to 3/8" material and it seems to short for me. I think Im going to try and get a mounting plate. Does anyone know where I can get one? I couldnt find anything on happs website.
leafblade
Re: wico mounting
« Reply #7 on: December 26, 2004, 06:35:01 am »
try:
 www.therealbobroberts.com
he has a mounting plate for $10.00
Are these suitable for wico's?
« Last Edit: December 26, 2004, 07:43:32 am by leafblade »
