Author Topic: Optipac - works in windows, not in mame?  (Read 1631 times)
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« on: November 30, 2004, 09:38:36 pm »
First off, I think this is a simple config question - but I can't seem to track it down.
I noticed that menace posted with the exact same problem back in July, but no one came forward with the solution.
Basically I have a spinner hooked up to my USB optipac. It works fine in windows - mouse pointer moves up and down (x axis hooked up) or left to right (y axis). Also seems fine in either P1 rotary or P1 trackball. I have nothing else plugged into the optipac.
As soon as I start a game in mame, I can't get the spinner to register. I've been testing with ikari warriors. I've tried Mame 0.89 and (Analogmame 0.83 and 76...)
In mame.ini I have:
mouse
Silver
    • Mods'n'Mods
Re: Optipac - works in windows, not in mame?
« Reply #1 on: November 30, 2004, 10:07:26 pm »
Ok I've made some progress I think - it looks like it DOES work in mame, but it just won't detect it for selection?
 For example if I use my PS2 mouse to set the axis (eg mouse 1 Yaxis) for the dial in ikari, I can then use my spinner plugged into the Yaxis on the optipac to rotate the gun in gameplay(with some heft analogue control adjustments). However, with no ps2 mouse in I can not select this axis as mame will not detect it.
I can only presume this is a sensitivity issue, as in windows my spinner is much less sensitive than the mouse. Anyone shed some light on how mame detects movement?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: December 01, 2004, 07:21:36 pm »
I'm not exactly sure why mame has problems with the mouse axes, but it's partially based on that analog remapping needs a large value.  As you say, with your spinner slower than your mouse, it's probably that mame isn't getting a big enough delta.  However, if you spin a mouse/trackball/spinner too fast, mame doesn't "see" it correctly, either.  :(
As I said, don't know why.  Not much help, I know...  [shrug]
FWIW, it's easier to remap mice through a ctrlr file ATM.
Robin
Knowledge is Power
Silver
    • Mods'n'Mods
« Reply #3 on: December 01, 2004, 07:36:42 pm »
Ah - I figured it might be this. The 'spinner' is more like a rotary joystick in that it spins with a series of 'clicks' (24 in 360 degress) but kicks out a 2 channel with phase dfference output (just like spinners/trackballs optical output). I can make the windows mouse cursor fly up and down the screen, but with a large series of tiny pauses (the clicks), and I'm guessing these pauses are what is stopping mame from detecting it.
Thanks - this will avoid the problem for me nicely.
