Author Topic: NE1 Used an adjustable hole saw?  (Read 2031 times)
Tiger-Heli
    • Tiger-Heli
« on: September 28, 2002, 08:40:47 am »
I was in Lowe’s yesterday, and they sell a hole saw that adjusts from 1-1/8” to 2-1/2 inches for around $10.  Basically 3 blades 120 degrees apart and you turn a camlock to set the diameter.
Anyone know how well they work.  Might be the only holesaw I have to buy if it’s any good.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:NE1 Used an adjustable hole saw?
« Reply #1 on: September 28, 2002, 08:51:57 am »
I contemplated the same thing tiger Heli... but I opted to just buy a fixed size...  (what other sizes do you think you'll need than 1 1/8" ?)
I was worried that it wouldn't be as sturdy/sharp/stay as sharp as  a fixed width one...
I also opted for the fix width because the adjustable size ones can only "spin" in one direction... therefore it might put a crimp in my pan to cut lexan by running the drill in reverse to melt it..
But other than those concerns... I don't see why it wouldn't work.
Maybe someone else has actually used one and can give a more qualified answer.
rampy
Xiaou2
  • Last login:Today at 03:05:55 am
  • NOM NOM NOM
« Reply #2 on: September 28, 2002, 10:45:56 am »
They suck.  Stay away.  They break easily, and arnt perfectly alligned so mess up the hole anyway.
Get a 'real' heavy duty holesaw, and or spade bits.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: September 28, 2002, 10:49:05 am »
Ok, that's what I was afraid of.  Thanks!!!!
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: September 28, 2002, 12:33:27 pm »
The SW yoke will need a 2-inch.  The 2-1/4 trackball enclosure will require some size, but I don't know what as of yet.
