Author Topic: ACT LABS USB TV GUN AND MAME  (Read 1517 times)
teksta1701
  • Last login:November 28, 2004, 03:25:44 pm
« on: November 25, 2004, 03:00:36 pm »
Hello All,
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: ACT LABS USB TV GUN AND MAME
« Reply #1 on: November 25, 2004, 06:12:18 pm »
Use either lightgun  1 in your ini file or put -lightgun on your command line arguments.
Later,
dabone
(Now if someone can tell me how to get both of mine working at the SAME time under mame)
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #2 on: November 26, 2004, 01:31:04 pm »
To get both guns working you have to use MameAnalog+
I have both of mine working perfectly under Analog+
dabone
  • Time to work...
« Reply #3 on: November 26, 2004, 09:41:49 pm »
Can you send me or post your ini file?
Also, what version of analog are you running and what operating system?
Later,
dabone
StephenH
« Reply #4 on: November 27, 2004, 04:47:37 am »
Make sure lightgun support is enabled.  Also, if you are running Command Line, make sure you are loading Windows and running from a Windows DOS Box with the USB Drivers installed.   Many USB Devices do not work in Pure DOS.
clanggedin
  • O'DOYLE RULES!!!
« Reply #5 on: November 27, 2004, 03:31:42 pm »
I am running WinXP and my ini file has both light guns enabled with auto reload. I have the latest version of Analog+ which I believe is .76 or something.
All of the changes were made once Analo+ was started in the controls section. I just had to tweak a few settings in some of the gun games to get both guns to work.
dabone
  • Time to work...
« Reply #6 on: November 27, 2004, 07:26:10 pm »
Would you mind posting your mame.ini and at least one of the gun games ctrl file so I can get a clue as to what I'm doing wrong.
If I use a current version of mame or just enable dual lightgun in mame.ini, both my guns are mouse button 0, and they both can shoot.
If I enable the analog mame lightguns and xp multimouse raw mode, I can get the different mouse buttons, (mouse 2 button 0, mouse 3 button 0) but then the guns won't move on the screen.
Help...
Please...
I've tried all the analog mame version back to .74 and I must just have a big ole brain block, because I'm just not getting it.
Thanks,
later,
dabone
clanggedin
  • O'DOYLE RULES!!!
« Reply #7 on: November 27, 2004, 09:02:17 pm »
Here is the portion of the analog .ini file that pertains to dual guns:
### Input device options ###
mouse
« Last Edit: November 27, 2004, 09:24:15 pm by clanggedin »
