Author Topic: Need suggestions for cabinet sides finish...  (Read 2104 times)
Animeka
  • Last login:November 11, 2015, 11:21:44 am
    • Subnet192
« on: September 27, 2002, 10:51:33 am »
Hi everybody,
i just bought an old arkanoid cab with a wood grain finish. I want to get rid of that so I need to cover it somehow. Any suggestions on what to do?
I had a suggestion of using car stripping material (36" rolls) and covering the sides.
There's also sanding/painting but I don't think I want to get into the mess of sanding the whole thing.
Suggestions are MORE than welcome :)
Marc
« Last Edit: September 27, 2002, 04:17:45 pm by Animeka »
Yarb
  • Last login:December 26, 2019, 01:18:30 pm
Re:How to finish the sides?
« Reply #1 on: September 27, 2002, 01:10:13 pm »
If you want to hide the grain without using a filler-primer and sanding I'd say using a laminate would be your best bet
Yarb
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Need suggestions for cabinet sides finish...
« Reply #2 on: September 27, 2002, 05:58:17 pm »
Its actually not......... Laminate to bare wood, not on top of paper laminate! You've just stuck your expensive laminate to paper... NOT a good option.
If you want to do it on the cheap I'd say prime and paint. Mess or not though, theres really no substitute for a good old fashioned stripping. Sorry. :) With just paint you'll still see the woodgrain through the paint. I've had this happen with a cheap shelf I've painted before. Its not neccesarily a bad look, but be warned it will peek through.
If you build a frankenpanel, chances are I don't care for you as a person.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: September 27, 2002, 07:29:11 pm »
The cabinet that I converted is an old Taito, that mighta been an arcanoid cabinet... It had a faux woodgrain laminate.
I pried off the laminate (it was in so -so shape)... unfortunately my site is down or I could show you my cabinet, and pictures during the removal process...
I'd recommend if you hated the woodgrain and it is laminate... to strip it (I just used a putty knife... but a heat gun woulda helped loosen the contact cement) and relaminate it...
I had so so results sanding it after removing the laminate, priming with tinted primer and painting semi gloss black...
*EDIT* ha... I'm back in action my temporary site depicting turning and old Taito cab into ubercade
rampy
« Last Edit: September 27, 2002, 11:03:24 pm by rampy »
