Author Topic: Would this fit?  (Read 1348 times)
AlanS17
    • AlanS17
Would this fit?
« on: November 11, 2004, 10:05:47 am »
Could I get a KDS 21 Inch" monitor (with casing) to squeeze into a standard-sized Ms. Pacman cocktail cabinet? Anybody tried this?
paigeoliver
  • Awesome face!
Re:Would this fit?
« Reply #1 on: November 11, 2004, 10:31:36 am »
It should BARELY fit. Worst case scenario you will have to modify the frame.
Lilwolf
Re:Would this fit?
« Reply #2 on: November 11, 2004, 10:40:23 am »
I will try and measure them tonight.  I don't have a ms-pacman cab but I have two kds monitors.
btw, those monitors aren't all that good for mame (too high resolution) but GREAT for PC games ect.  Also GREAT for all vector games...
paigeoliver
  • Awesome face!
Re:Would this fit?
« Reply #3 on: November 11, 2004, 11:11:55 am »
I have BOTH, give me two minutes.
paigeoliver
  • Awesome face!
Re:Would this fit?
« Reply #4 on: November 11, 2004, 11:16:24 am »
It BARELY fits, and you have to lose the case. Which you don't need anyway. If you aren't familiar with the setup, here is how it goes.
The monitor tube, and boards, and all of it are attached to a sturdy front mounting plate, it is all attached to that plate, nowhere else. The rest of the fram can be removed and you will hang your monitor down into the cocktail from the mounting plate. It will be a pretty easy install.
It won't work with the case on though, even if you got it in there you wouldn't be able to get anything else in there with it, you need that extra space.
AlanS17
    • AlanS17
Re:Would this fit?
« Reply #5 on: November 12, 2004, 03:24:13 pm »
I was expecting to remove the casing anyways. I'm glad to hear that everything stays intact, though.
Would I have to enlarge the cut-out where the monitor shows through?
paigeoliver
  • Awesome face!
Re:Would this fit?
« Reply #6 on: November 12, 2004, 04:04:42 pm »
Not sure, I didn't fully investigate it, I just measured it up real quick. If you did have to enlarge it, then it wouldn't be by much, as the tube on the KDS is just BARELY bigger than the tube on a 19" G07 monitor.
AlanS17
    • AlanS17
Re:Would this fit?
« Reply #7 on: November 17, 2004, 12:22:30 pm »
Well enlarging a little or a lot probably requires the same amount of effort (and more importantly, the same room for mistake). Any expansion at all kind of turns me off to the idea.
fredster
  • It's all good!
Re:Would this fit?
« Reply #8 on: November 17, 2004, 02:58:04 pm »
Yes, it will fit. It's tight, but it will fit Horizontally.  Vertically, you may have to knock out the back plate and move it.
