Author Topic: Old vinyl Issues  (Read 1332 times)
brained
  • Last login:September 10, 2025, 10:35:06 am
  • Raised by Atari
    • Nux
Old vinyl Issues
« on: November 04, 2004, 06:33:54 pm »
Hi all, I tried to remove the old vinyl on the sides from my cab, but it seems to be somewhat crispy. I did the blower thing to heat it up, but no luck. Has some one tried to remove vinyl that
SirPeale
  • Green Mountain Man
Re:Old vinyl Issues
« Reply #1 on: November 04, 2004, 08:31:07 pm »
You're doing the right thing, but you'll just have to work slowly.  Heat the vinyl until it starts becoming maleable, then start peeling it off bit by bit.  It'll likely take a while.
Tailgunner
Re:Old vinyl Issues
« Reply #2 on: November 04, 2004, 08:31:17 pm »
Belt sander and a fairly coarse belt. Also a wire brush to keep the vinyl from clogging up the belt.
How will you be recovering the cab? If painting you'll need a fine grit belt to remove any deep scratches left from the removal process.
brained
  • Raised by Atari
    • Nux
Re:Old vinyl Issues
« Reply #3 on: November 05, 2004, 07:48:44 am »
Well the problem is that I'm using a Hair Dryer instead of a heat gun, so you recommend me get a heat gun or just heat a little longer with the hair dryer.
I'm removing this old vinyl to replace with some blue vinyl. And also i need to repair a few dents and a little water damage.
Goz
  • KOTA
Re:Old vinyl Issues
« Reply #4 on: November 05, 2004, 09:12:55 am »
I had this very same problem. I wouldn't buy a heat gun to do this. If you have other needs of a heat gun, buy one it will go a little bit faster than the hair dryer. Even when it heats up and becomes pliable, it will still come off in sections / strips.
It may take several hours to do it this method, but it will likely save you from having to sand.
-Goz
brained
  • Raised by Atari
    • Nux
Re:Old vinyl Issues
« Reply #5 on: November 05, 2004, 01:36:53 pm »
hmmm.. I see, so I'll give it another try.
Ohhh, a friend of mine told me that paint remover is ok for that, but I dunno if the particle board will handle paint remover.
I did remove the vinyl from my metal cp using paint remover applied with a brush and in small quantities it's usefull but kinda messy.
Do you think paint remover won't damage the particle board?
brained
  • Raised by Atari
    • Nux
Re:Old vinyl Issues
« Reply #6 on: November 06, 2004, 06:23:34 pm »
Well I've continued trying and the vinyl crumbles with the particle board....
What can I do, can I paint over the vinyl?
or
can I cover the vinyl with more vinyl....
Please gimme some light in this subject I'm confused...
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re:Old vinyl Issues
« Reply #7 on: November 06, 2004, 07:19:20 pm »
sand it off..
