Author Topic: Questions About Dreamcast to Cabinet  (Read 3397 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: September 14, 2002, 11:34:39 pm »
Hi,
I have checked some Faqs and info here but I still am not seeing any kinda of clear cut ways to hook up a dc to my cabinet. anyone have any links to how to do this? also I know its possible to wire it to your controls, but will the interface still work for mame etc?? (like it does now)? sorry newbie..i want to add a dc to my cabinet and maybe ps2 down the road..any help is very much appreciated..
thx
Jim
SNAAAKE
  • -Banned-
Re:Questions About Dreamcast to Cabinet
« Reply #1 on: September 15, 2002, 02:13:47 am »
you can hack a cheap psx pad then use that for dreamcast too.(psx to dreamcast converter)
all you gotta do is make a switch between your current interface ground.....you can get a flip switch from radio shack then just switch the grounds for you current interface to your psx/dreamcast interface...i am doin similer stuff..
i used to plug/unplug converter everytime i played mame or dreamcast.now i just flip a switch to switch between interface and that way you have all in one.
i will provide the whole detail in my site when i am complete but you get the idea right?
also what kind of monitor are we talkin here?
if its tv then you are in luck.if pc monitor then you get vga monitor and a vga switch box.if things are not clear then post again and i will try to explain more. :)
« Last Edit: September 15, 2002, 02:15:13 am by SNAAAKE »
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #2 on: September 15, 2002, 02:40:26 am »
I've been helping to get a new "Consoles" section up on the site, but is hasn't been linked in yet.  I think this will answer most of your questions.
http://www.arcadecontrols.com/arcade_consoles.shtml
-Dave
« Last Edit: September 15, 2002, 02:40:54 am by Dave_K. »
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #3 on: September 15, 2002, 03:27:55 am »
i got this dandy thing to play television signals on any pc :) callexd a tv tuner video card mmmm to bad it doesnt have coax output id be playing stuff on my tv lol using my pc a well massive vediogame system / vcr hmm....... soon to come...... if i can get a freaking nouther moitheboartd! that runs more then 100 mhz!
Slow In Fast Out
SNAAAKE
  • -Banned-
« Reply #4 on: September 15, 2002, 03:50:38 am »
video cards have av and s-video inputs.
so look for one of that if you have a pc monitor in your cab at the time.
Demon-Seed
« Reply #5 on: September 15, 2002, 07:08:15 am »
Hey Guys,
Some good info there just wanted to add a few things:
-i am running from arcade cp to PC monitor so I would need a  convertor.
-snake-your info sounds good but i was hoping for a little more step by step info as i am not too bright. eheh....let me know if u get the site up i guess.
-also any suggestions on where to start?? which system is teh simplest?
thx
Jim
Demon-Seed
« Reply #6 on: September 15, 2002, 07:18:24 am »
http://www.lik-sang.com/info.php?category=53&products_id=1892&
is this the sort of thing i need to connect system to cabinet? but how can i have multi systems? do they make a multi convertor so i do not have to unplug etc?
SNAAAKE
  • -Banned-
« Reply #7 on: September 15, 2002, 09:45:39 am »
well,
for multi systems,you can hack pads for each system then use a swtich box(printer switch box).you get the 4 port switch box and you can have upto 4 systems.you only need to switch just the ground and you can solder all the normal connection together(all the regular contacts from each interface).
this should be easy but
EASIETS would be to hack a cheap psx pad then get converter for dreamcast,usb-pc,x-box,etc.
and the question is,do you really wanna hack all the controls? :P
x-box controls seems great pain and the system pretty much suck for the time being. :(
i can explain more if things are not clear yet. :)
Demon-Seed
« Reply #8 on: September 15, 2002, 04:44:15 pm »
So u hack a psx controller. got that and then it goes into a box that can split into other systems?? i am not sure how its done without physcally switching cables etc....
are there any clear plans with diagrams> or something??? ia m not sure what i need to do or where to start..and i really do not want to mess anything up..ehee
Jim
Lilwolf
« Reply #9 on: September 15, 2002, 05:06:57 pm »
Anyone have a good solution for analog controls for the dreamcast yet?
Dave_K.
    • Arcade Fever
« Reply #10 on: September 15, 2002, 05:19:09 pm »
I gave a couple suggestions for analog controls in the new console section (above).
-Dave
