Author Topic: Key strokes stuck.  (Read 1517 times)
sanousuke
  • Last login:March 13, 2009, 05:21:37 pm
Key strokes stuck.
« on: September 23, 2004, 04:01:10 pm »
When I play mortal kombat or any game where you gotta move the joystick alot, the controls get stuck. Like if I move left, it will keep moveing left even after I release it. It does this with all my controls.
I'm not sure if this is a windows thing or if my keys are actually getting stuck, but that doesn't seem like the case.
Has anyone else had this problem or know how to fix it?
Hoagie_one
  • Um....whats a cabinet
Re:Key strokes stuck.
« Reply #1 on: September 23, 2004, 04:07:19 pm »
what encoder are you using?
sanousuke
« Reply #2 on: September 23, 2004, 04:08:08 pm »
The ipac4.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #3 on: September 23, 2004, 05:57:44 pm »
are you using it in usb mode or ps/2?  try switching it and see what happens..
« Last Edit: September 23, 2004, 06:21:48 pm by Bgnome »
SirPeale
  • Green Mountain Man
« Reply #4 on: September 23, 2004, 08:03:32 pm »
I'm thinking maybe it has something to do with typematic rate.
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #5 on: September 23, 2004, 08:45:45 pm »
Are you using Windows XP?
sanousuke
« Reply #6 on: September 24, 2004, 03:05:31 am »
Sorry, I was at work, so I couldn't reply.
I'm using usb and windows xp.
Rapid Axlr8ion
  • Last login:September 24, 2004, 02:09:55 am
  • When in doubt...Whip it out!!!
« Reply #7 on: September 24, 2004, 03:36:17 am »
I have heard people having better luck with PS/2 instead of USB...I'm not completely sure why, but I use PS/2 without any problems with Windows XP
JODY
« Reply #8 on: September 24, 2004, 10:00:13 pm »
There have been threads on here in the past with problems with Windows XP and USB just like the previous poster said.  I've got Windows XP and when using the USB keyboard I experience issues from time to time.
For example, may be playing pacman and all of a sudden the keyboard doesn't respond correctly.  It appears that previous keystrokes (or repeated keys by holding keys down) build up in a buffer and get read and responded to later.  If I don't press a key for a few seconds it usually goes back to normal, but it sometimes takes a few minutes.
I have not had the problem when using a keyboard encoder connected to the standard keyboard input but have heard of others having the problem with keyboard encoders connected to USB.
You might try playing around with the keyboard key repeat properties to see if it has an impact.
sanousuke
« Reply #9 on: September 25, 2004, 06:44:38 am »
The problem I was haveing was alot worse then this. I fixed it now.  Still not sure why the buttons were getting stuck.
My problem was that my joysticks were put together wrong. The little knob on the bottom of the joysticks that push on the plates were backwards. I had the little side of the knob hitting on the plates, so I switched them and now i'm able to move freely in a game easily.
Now, i'm haveing the occasional problem you just describe. Which isn't really a big deal, not compared to the other.
