Author Topic: Always rotating any vertical game  (Read 1721 times)
SirPoonga
  • Puck'em Up
  • Last login:July 09, 2025, 04:08:29 pm
  • The Bears Still Suck!
« on: August 29, 2002, 08:10:03 pm »
requires compiling mame
Add to \src\windows\config.c
   /* if this is a vertical game, parse vertical.ini else horizont.ini */
   if (drivers[game_index]->flags & ORIENTATION_SWAP_XY) {
      if (parse_config ("vertical.ini", NULL))
         exit(1);
   } else {
      if (parse_config ("horizont.ini", NULL))
         exit(1);
Put that right after the section that does the vector.ini fil
so it looks like:
   /* if this is a vector game, parse vector.ini first */
   expand_machine_driver(drivers[game_index]->drv, &drv);
   if (drv.video_attributes & VIDEO_TYPE_VECTOR)
      if (parse_config ("vector.ini", NULL))
         exit(1);
         exit(1);
   } else {
         exit(1);
Now you can make a horizont.ini and vertical.ini
If you want to rotate vertical game in the vertical.ini put ror 1 or rol 1 in it.
