February 01, 2026, 05:09:32 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Main
Monitor/Video Forum
Composite Sync vs H + V Sync (Light gun on Sayno 20EZ 19")
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Composite Sync vs H + V Sync (Light gun on Sayno 20EZ 19") (Read 4251 times)
chrisinauz
Trade Count:
0
Full Member
Offline
Last login:February 21, 2005, 01:07:54 pm
I'm a llama!
on:
July 30, 2004, 04:07:16 pm »
I have a Sanyo 20EZ 19" Monitor from a Nintendo machine, it has a composite sync wire hooked through to a VGA Amp, I would like to use a light gun but heard you NEED H Sync and V Sync wires seperate.... Is there a way to just slip the composite sync wire to get it working with the Act Labs USB Light Gun??? Has anyone ever got that light gun working on a Sanyo 20EZ?
Logged
MonitorGuru
Trade Count:
0
Full Member
Offline
Last login:October 05, 2005, 11:29:43 pm
Re:Composite Sync vs H + V Sync (Light gun on Sayno 20EZ 19")
Reply #1 on:
July 30, 2004, 04:19:58 pm »
You might be able to run the same wire into both H and V inputs and if the electronics are advanced enough it will split them for you. Or you can build/buy a sync splitter circuit to split the H and V apart.
Logged
initial_y
Trade Count:
0
Jr. Member
Offline
Last login:July 31, 2004, 02:14:19 am
I'm a llama!
Reply #2 on:
July 31, 2004, 02:16:39 am »
I want to build a sync splitter myself but can't find the circuit , could you tell me one?
Logged
Stiffler
Trade Count:
0
Jr. Member
Offline
Last login:October 04, 2004, 12:12:14 pm
I'm a llama!
Reply #3 on:
August 02, 2004, 03:30:19 pm »
If the VGA amp is from Ultimarc, then it can split the
Composite Sync for you. The directions should of
came with the amp on CD or you can find the directions
on Ultimarc's web site.
Logged
dabone
Trade Count:
0
Full Member
Offline
Last login:July 15, 2025, 08:32:17 pm
Time to work...
Reply #4 on:
August 02, 2004, 04:00:45 pm »
Ok, I understand your problem. The monitor you have ONLY accepts negative composite sync. So unless someone has a hack for the monitor board itself, you are outta luck getting it to work with the pc lightguns.
Later,
dabone
Logged
CthulhuLuke
Trade Count:
+1
Full Member
Offline
Last login:May 22, 2025, 01:03:42 am
old school
Reply #5 on:
August 03, 2004, 05:12:12 am »
if you want to permanently convert your monitor to RGB, this guy sells an inverter kit for 5 bucks,
http://users.rcn.com/jenison/mars/trouble/part/monitors/fixitkits.html
but you'll have to do some pcb work on the monitor.
Logged
dabone
Trade Count:
0
Full Member
Offline
Time to work...
Reply #6 on:
August 03, 2004, 07:32:15 am »
That still will not give the monitor seperate sync inputs.
Some monitors just won't work with the guns.
Later,
dabone
Logged
jerryjanis
Trade Count:
0
Full Member
Offline
Last login:February 02, 2023, 01:56:44 am
Skate or Die!!!
Reply #7 on:
August 03, 2004, 07:57:34 am »
This probably won't help you, but I thought it might possibly be worth mentioning. My monitor (a Wells Gardener 25k7191) originally had a pin for vsync, but no actual wire. I added a wire for vsync, and it worked with my lightgun:
http://www.jstookey.com/arcade/WG_25k7191/WG_25K7191_output.JPG
(click for a huge picture)
Last Edit: August 03, 2004, 08:00:41 am by jerryjanis
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
