Author Topic: Composite Sync vs H + V Sync (Light gun on Sayno 20EZ 19")  (Read 4257 times)
chrisinauz
  • Last login:February 21, 2005, 01:07:54 pm
« on: July 30, 2004, 04:07:16 pm »
I have a Sanyo 20EZ 19" Monitor from a Nintendo machine, it has a composite sync wire hooked through to a VGA Amp, I would like to use a light gun but heard you NEED H Sync and V Sync wires seperate.... Is there a way to just slip the composite sync wire to get it working with the Act Labs USB Light Gun??? Has anyone ever got that light gun working on a Sanyo 20EZ?
MonitorGuru
  • Last login:October 05, 2005, 11:29:43 pm
Re:Composite Sync vs H + V Sync (Light gun on Sayno 20EZ 19")
« Reply #1 on: July 30, 2004, 04:19:58 pm »
You might be able to run the same wire into both H and V inputs and if the electronics are advanced enough it will split them for you.  Or you can build/buy a sync splitter circuit to split the H and V apart.
initial_y
  • Last login:July 31, 2004, 02:14:19 am
« Reply #2 on: July 31, 2004, 02:16:39 am »
I want to build a sync splitter myself but can't find the circuit , could you tell me one?
Stiffler
  • Last login:October 04, 2004, 12:12:14 pm
« Reply #3 on: August 02, 2004, 03:30:19 pm »
If the VGA amp is from Ultimarc, then it can split the
Composite Sync for you. The directions should of
came with the amp on CD or you can find the directions
on Ultimarc's web site.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: August 02, 2004, 04:00:45 pm »
Ok, I understand your problem. The monitor you have ONLY accepts negative composite sync. So unless someone has a hack for the monitor board itself, you are outta luck getting it to work with the pc lightguns.
Later,
dabone
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #5 on: August 03, 2004, 05:12:12 am »
if you want to permanently convert your monitor to RGB, this guy sells an inverter kit for 5 bucks, http://users.rcn.com/jenison/mars/trouble/part/monitors/fixitkits.html  but you'll have to do some pcb work on the monitor.
dabone
  • Time to work...
« Reply #6 on: August 03, 2004, 07:32:15 am »
That still will not give the monitor seperate sync inputs.
Some monitors just won't work with the guns.
Later,
dabone
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #7 on: August 03, 2004, 07:57:34 am »
This probably won't help you, but I thought it might possibly be worth mentioning.  My  monitor (a Wells Gardener 25k7191) originally had a pin for vsync, but no actual wire.  I added a wire for vsync, and it worked with my lightgun:
http://www.jstookey.com/arcade/WG_25k7191/WG_25K7191_output.JPG
(click for a huge picture)
« Last Edit: August 03, 2004, 08:00:41 am by jerryjanis »
