Author Topic: multiple spinners on cocktail  (Read 1434 times)
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
« on: July 14, 2004, 09:39:48 am »
I built a cocktail that has the two normal control panels as well as a side panel. I have trackballs and spinners on all three panels. I am using an optipac, however this set up will leave me one axis short. (3 trackballs at 2 axis each and 3 spinners will total 7 axis.) The optipac supports 6.
     I have built cabs like this before and used a small toggle to switch between player one's spinner on the side and end panels. I really do not like this approach. I was wondering if any of you had any ideas to eliminate the switch.
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
NoOne=NBA=
Re:multiple spinners on cocktail
« Reply #1 on: July 14, 2004, 10:54:58 am »
Ummm.......3*2=6, and 3*1=3.
That's NINE.
You're going to fill the Opti-pac with the trackballs alone.
The switch method is the easiest approach.
You could add a couple mouse hacks to this, but I don't see any reason to when you can just switch controls on the interface you've got.
sirwoogie
  • Supreme Chancellor
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
« Reply #2 on: July 14, 2004, 11:36:23 am »
NoOne is right, that is 9. Instead of a workaround, why not just buy another optipac?
NoOne=NBA=
« Reply #3 on: July 14, 2004, 01:07:14 pm »
I knew that 16 years of school I had would come in handy some day.
btoddkelley
« Reply #4 on: July 14, 2004, 01:08:58 pm »
M.A. in economics and i cannot do basic math! Yes, 9 axis. The optipac has 8 axis inputs so i only need one more.
Todd
- Descartes
sirwoogie
« Reply #5 on: July 14, 2004, 05:44:50 pm »
I guess a clarifying question: which spinner are you using? Realize if they are Tornados, they have their own encoder board thus needing a mouse/USB port. Some other spinners come with their own too.
btoddkelley
« Reply #6 on: July 14, 2004, 10:41:56 pm »
I build my own and use happs optical pickups. They wire directly to the optipac.
Todd
- Descartes
