Author Topic: Arkanoid high score information...  (Read 2241 times)
Bitnerd
  • Last login:July 07, 2004, 08:12:28 pm
« on: July 06, 2004, 09:02:48 pm »
Hey Ya'll,
As some of you know, I am restoring an Arkanoid and I was wondering if anyone out there knows which chip/IC on the PCB holds the high score infromation.  It always resets to a default everytime I power cycle it.  I thought I would look for a datasheet on the chip to see which pins I could solder a battery to.  I have already looked up some of the bigger chip numbers on google and it seems many of them are in the obscure file now.  If anyone has any suggestions, let me, know.
Thank you,
Bitnerd.
All that glitters is not gold...
All who wander are not lost
StephenH
Re:Arkanoid high score information...
« Reply #1 on: July 07, 2004, 02:32:42 am »
You might see if there is a battery on your board.  If you find one, replace it.  I beleive that is what maintains the high scores.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: July 07, 2004, 05:10:42 am »
By using Mame (since it is a documentation project after all) and the hiscore.dat file, I would guess chip a75_11.  However, the game does change these locations to the default values after powering up.  What this means is even if you battery backup the chip, the program will still put the default values into that chip overwriting your battery backedup values.
Bitnerd
« Reply #3 on: July 07, 2004, 09:20:16 am »
Hey Bro,
Thanx for the input.  I checked the board and there is no battery that I can see.
Bitnerd.
Bitnerd
« Reply #4 on: July 07, 2004, 09:22:45 am »
Thanx for the info.  I located the chip right away.  That is a real bummer.  I wonder how I could do a workaround short of keeping 5V on the entire board.  Would there be a way to keep the default from being written to that chip? Hmmmmmmm.  Thanx again man.  Good information Bro, thanx.
Cheers,
Bitnerd.
« Last Edit: July 07, 2004, 09:33:00 am by Bitnerd »
