Author Topic: Xp boot into mAmewah  (Read 1757 times)
mortymoose
  • Newbie
  • Last login:June 14, 2004, 04:11:05 pm
« on: June 14, 2004, 04:14:10 pm »
Greetings to all..my cab is almost finished..however i remember in 98se , i could just edit the autoexec,bat to get windows to boot directly to arcadeos...however i know use xp pro and mamewah..how do I set xppro up to boot directly into mamewah......
thanks
morty
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
Re:Xp boot into mAmewah
« Reply #1 on: June 14, 2004, 04:33:40 pm »
The only way I know of (there are probably other (better?) ways) is to place a shortcut to MAMEWAH.exe in your startup folder in the start menu.  This way, every time you boot into windows, it boot MAMEWAH.
Of course, it goes through the whole shabang of loading windows first, then it starts your fe.  I doubt there is a way to get around this.
Have fun :)
...they only live twice!...
(>")>----MAME----<("<)
Antix
  • Last login:July 02, 2018, 11:06:06 pm
  • Burp!?
« Reply #2 on: June 14, 2004, 04:37:38 pm »
You could also use a program like ApptoService or Svrany to load the program as a service. This would then load when windows boots as well..... But once again, windows must boot up first.
Im working on something similar at the moment, but having problems with XP. Have now gone to win98, and once that is going will move the settings into XP to see if that works :)
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
« Reply #3 on: June 15, 2004, 12:17:17 pm »
On a similar note...
I set up Mamewah and Joy to Key last night to run from the startup folder.  It boots up but then seems to lose focus because I can't select anything.  Via Keyboard or controls.  I have opened task manager and nothing else is running that I can see and if I switch to Mamewah it runs fine but I can't boot straight to Mamewah and have it usable.  Any suggestions anyone?  Anyway to see hidden programs that maybe running?
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #4 on: June 15, 2004, 08:17:24 pm »
this article describes how it is possible to replace the standard windows shell
http://shell-shocked.org/article.php?id=133
maybe it is possible to make MameWAH (or another FE) the shell?
