Author Topic: PC Power Supply Question  (Read 1309 times)
Gameboy.au
  • Last login:January 11, 2005, 05:54:15 am
  • Cabinet completion: 65%
« on: June 06, 2004, 02:36:57 am »
Hi all,
I'm using a spare PC power supply (AOpen microATX Model FSP145-60SI) for all of my illumination needs, however, I've hit a brick wall.
Does anyone know which wires to short/connect to force the power supply to power up?
I just assumed that it was the "Power Good Signal" wire to one of the Ground wires.  After doing this and nothing happening, I can gladly report that I am dead set wrong.  :-[
Any help would be great.
Cheers guys.
The internet, hey... so they have that on computer's now???
Industen
  • Last login:December 15, 2014, 03:16:41 pm
  • Visit my WWW page below
    • Joel's Main Mame Page
Re:PC Power Supply Question
« Reply #1 on: June 06, 2004, 02:58:45 am »
I wrote up how to do this on my website. It's toward the bottom.
http://joelsgadgets.com/PopnMusic2.html
« Last Edit: June 06, 2004, 03:00:21 am by Industen »
MameMe
  • Last login:June 08, 2005, 06:45:25 am
« Reply #2 on: June 06, 2004, 07:55:09 am »
If I can jump on this thread, after performing the hack which wires from the molex should be used to lets say power up some cooling fans?  I think the molex connectors have 4 wires (off the top of my head) right?
Industen
« Reply #3 on: June 06, 2004, 09:55:53 am »
Well assuming you don't have molex type cooling fans that you can just connect to the PS you can tap into the yellow (12-volt) and black (ground) wire to power them. Or you can use the red (5-volt) and black (ground) to power a 5-volt source.
« Last Edit: June 06, 2004, 09:56:39 am by Industen »
ratabase1
  • Last login:August 24, 2020, 09:51:51 pm
« Reply #4 on: June 06, 2004, 09:58:20 am »
To see how to hook up lights or fans to a PC Power supply see blakesmame website:
http://www.blakesmame.com/power.htm
It has a small write up on this.
Gameboy.au
« Reply #5 on: June 07, 2004, 06:36:09 am »
Thanks guys!    ;D
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #6 on: June 07, 2004, 11:39:06 am »
You can also use the 12 volt  (yellow) and the 5 volt (red) to power a fan at 7 volts...
-wj2k3
Gameboy.au
« Reply #7 on: June 07, 2004, 06:59:29 pm »
Actually, I wanted it mainly for the 12V fluros that I have hooked up for the marquee.
I just bought some cheap 500mm long workshop fluros that run off a car battery.  Solves my lighting problem.  :D
