Author Topic: Translucent blue trackball..Photos?  (Read 3718 times)
sirhcman
  • Last login:January 20, 2008, 01:50:45 pm
« on: August 01, 2002, 10:38:06 pm »
I am thinking about going with the imperial translucent blue trackball but I dont recall ever seeing a cabinet with one...Does anyone have any photos of the ball lit and unlit? Any help is appreciated!
CHRIS
ampapa
  • Last login:August 04, 2002, 09:59:21 pm
Re:Translucent blue trackball..Photos?
« Reply #1 on: August 04, 2002, 10:01:19 pm »
Take a look at my site and you'll find a few pictures with a
translucent "Blue" trackball.
- ajmmame/webajm.com
ampapa, :D
sirhcman
« Reply #2 on: August 04, 2002, 11:06:53 pm »
thanks but whats the webpage?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: August 05, 2002, 08:55:19 am »
I can't be sure... but it looks like he just had a typo...
a quick google search found this site:
http://ajmmame.webajm.com/
it has a glowing blue trackball so I'd guess that's the site...
good luck,
rampy
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
« Reply #4 on: August 05, 2002, 09:19:52 am »
Here's a pic..it's kind of blurry though...sorry...
http://www.doughansen.net/arcade/cp2.jpg
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
jginiso
  • Last login:January 23, 2009, 01:41:17 pm
« Reply #5 on: August 05, 2002, 03:53:06 pm »
What are you using to light that sucker?
James
txcanoeman
  • Last login:June 23, 2018, 12:01:10 am
« Reply #6 on: August 05, 2002, 06:00:23 pm »
FYI, I went the translucent blue trackball way, used an extra power line from my PC to light the bulb I bought from HAPPS.
However, I wouldn't do this again.  It isn't hard, it is just hardly worth it.  The lights are usually on in the gameroom and you can only see it glowing if you look down on it.
Next time I would put in a pool ball since they are the same size.  Either an 8 ball (black), or a 2 ball(blue)  to match the controls on my panel which are currently all blue.
Just my 2 cents.
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #7 on: August 05, 2002, 07:51:29 pm »
In my case when I bought the Happs trackball that had the bulb preinstalled with the 3" blue translucent ball, and like a lot of other people I've heard about, it was enough to heat the ball for an hour and make it expand so it wouldn't actually spin right.  So my solution, wire up a bright blue LED to a 12v adapter, with the correct resistors.  So now all I gotta do is plug in my LED and put it underneath the trackball, it's extremely bright blue shining on translucent blue, results a VERY cool looking milky-ish blue.
    -CthulhuLuke
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #8 on: August 05, 2002, 09:33:45 pm »
I also Illuminated my blue track ball with the high intensity Led's with resistors. instead ov running to a 12 volt supply
I ran it off of the 5v connection on my Opti-pac. I used 2 clear leds so I could light it fom 2 different angles.the main reasons I went with the leds is there is no heat from them.
and they will pretty much last forever.
                                       slug54
sirhcman
« Reply #9 on: August 05, 2002, 10:02:10 pm »
thanks for all the replies guys! appreciate the help.
