Author Topic: Get rid of Dell BIOS screen @ startup?  (Read 2469 times)
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
« on: May 26, 2004, 11:00:06 am »
Does anybody know how to get rid of a Dell screen that first comes up on startup?  Thanks!
-G
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
SirPeale
  • Green Mountain Man
Re:Get rid of Dell BIOS screen @ startup?
« Reply #1 on: May 26, 2004, 11:29:42 am »
There may be an option in the BIOS, but I doubt it.  The Dell people like to advertise.
I've got an eMachines motherboard with the same thing.  I'd love to turn it off for good, but that won't happen without a BIOS rewrite.
simplygriff
    • simplygriff.com
« Reply #2 on: May 26, 2004, 11:52:02 am »
I was afraid of that.  Thanks! :)
www.simplygriff.com
albarellij
  • Last login:October 24, 2018, 09:31:29 am
« Reply #3 on: May 26, 2004, 11:57:23 am »
Actually, my Emachines PC had a BIOS option, something like "Show Logo on Startup" or something, disabling that got rid of the logo.  So  definitely look around in the BIOS, it may be there. ;D
SirPeale
« Reply #4 on: May 26, 2004, 12:03:13 pm »
I did.  There's no option for it, unfortunately.
simplygriff
    • simplygriff.com
« Reply #5 on: May 26, 2004, 12:09:37 pm »
OK Newb here! ;D ??? ;D
How do I checkout my BIOS?
www.simplygriff.com
SirPeale
« Reply #6 on: May 26, 2004, 12:29:12 pm »
On powering up, you have to hit a key to enter your BIOS setup.  Not sure what it is on a Dell, but try one of these: [F1] [F2] [ESC] [TAB]
There also may be a message on boot stating what key to hit.
simplygriff
    • simplygriff.com
« Reply #7 on: May 26, 2004, 12:36:29 pm »
Oh Cool!  I've seen that.  I guess I just never really paid attention.  Thanks.
-G
www.simplygriff.com
Buddabing
« Reply #8 on: May 26, 2004, 12:39:47 pm »
I tried the three Dells I have access to at the office. On two of them I press the DEL key when starting up to access the BIOS. Typically I just press DEL repeatedly until the BIOS screens come up. DEL is very frequently used on non-Dells.
On the other Dell, I pressed CTRL-ALT-ENTER to access BIOS.
Please read the wiki!
Pasqualz
  • Last login:July 11, 2019, 06:57:13 pm
  • Boycott Turnips!
« Reply #9 on: May 26, 2004, 12:47:36 pm »
Try <F2> on a Dell, that usually works. You may find an option in the Dell BIOS for "Fast Boot" or something similar. This may disable the Dell splash screen and the memory count!
MAME me!
simplygriff
    • simplygriff.com
« Reply #10 on: May 26, 2004, 01:05:57 pm »
Nice.  I'll try it when I get home.  Thanks for everyone's help.
-G
www.simplygriff.com
maraxle
« Reply #11 on: May 26, 2004, 02:08:29 pm »
There are also programs out there that let you change the spash screen.  Check around for one for your particular chipset.  Be careful though, as you can really mess things up if you're not careful!
BeefyD
  • Last login:October 24, 2006, 02:51:35 pm
« Reply #12 on: May 26, 2004, 02:44:54 pm »
The only thing I found via Google was:
You will want to set 'Boot-Time Diagnostics Screen' to 'Enabled' in the BIOS. That should do it
From an old forum, though.... I guess this gets rid of Dell logo and shows diagnostics...
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #13 on: May 26, 2004, 08:54:36 pm »
Shouldn't you be able to update the BIOS, Peale?  I know  proprietary items are a favorite to use, but the motherboard should be a readily available thing, so I bet you can get a BIOS update and solve that.
SirPeale
« Reply #14 on: May 26, 2004, 09:08:09 pm »
I did find a site that said they had BIOS updates for the board, but I'm reluctant to use them, in case they hose the board.  It's not from the manufacturer, or I might try it.
DrewKaree
  • HAH! Nice one!
« Reply #15 on: May 26, 2004, 09:59:13 pm »
Gotcha.  Also, what about an onboard jumper or switch to clear the BIOS if you can't get at it via normal routes?  Usually there's one or the other, sometimes both.  It may reset your BIOS, but it'll reset the BIOS to defaults, so you won't be hosed that way.
SirPeale
« Reply #16 on: May 26, 2004, 10:13:26 pm »
Well, no, it would reset the BIOS to their defaut values, but if I over write the BIOS with a new set, and it's a bunk set, no amount of resetting will fix that.
