Author Topic: Happ's 3" Golden Tee Trackball -- Do I still need mounting plate?  (Read 1745 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
I'm about to order this:
http://www.happcontrols.com/trackballs/56010011.htm
Do I still need one of these:
http://www.happcontrols.com/industrial/trackballs/56553000.htm
Also, in case it matters, I'm going to hooking this up to an Opti-Pac along with a Vortex Spinner.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:Happ's 3" Golden Tee Trackball -- Do I still need mounting plate?
« Reply #1 on: May 23, 2004, 09:28:03 pm »
If you are planning to mount in wood, yes, a mounting plate would make your life easier.  Not mandatory but it is an easier approach than other options.
You may want to explore this option instead.  http://www.happcontrols.com/trackballs/55110100.htm
atog
  • Last login:January 30, 2015, 04:07:36 pm
« Reply #2 on: May 24, 2004, 03:29:19 pm »
yes as Zaphod said, it all depends on what you are mounting in.  My control panel is particle board bottom with a lexan top.  I was able to go without a mounting plate because of the lexan top, it basically acts as its own mounting plate.
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« Reply #3 on: May 24, 2004, 03:35:34 pm »
So a 1/8" piece of lexan is strong enough to support trackball play?  That's a good idea.
Lilwolf
« Reply #4 on: May 24, 2004, 04:52:51 pm »
take note though
the mounting plate is 10 bucks... maybe 12 at happs...
hack with lexan if you don't want it to look like a mounting kit... Otherwise just do it.
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
« Reply #5 on: May 24, 2004, 05:12:39 pm »
Can anyone comment on the quality of Happs' boltless mounting plate versus the "regular"?
b
What was that again?
zaphod
    • ArcadeCab.com
« Reply #6 on: May 24, 2004, 05:27:48 pm »
I've used the boltless version numerous times and have been very pleased with the quality and durability.  It's a nice product.
I have no experience with the other type.
« Last Edit: May 24, 2004, 06:39:59 pm by zaphod »
sofakng
« Reply #7 on: May 24, 2004, 05:40:35 pm »
Well, I ordered the mounting kit "just in case" I decide to use it.  I'd like the cabinet to look as professional as possible, so I'll probably end up just using lexan...
On a side note, do I have to do anything special to connect this trackball (Happ's 3" Golden Tee Trackball) to my Opti-Pac?  I heard I have to cut off a connector or something...
