Author Topic: Image twitch  (Read 1807 times)
Image twitch
« on: April 30, 2004, 12:18:07 pm »
I've got my Hantarex Polo connected up via an ArcadeVGA, and it works great, but one slight problem:  every so often the image kindof twitches up and back down ever so slightly (like one 'line').
It happens pretty randomly, and it is no biggie, but certainly a bit annoying at times.  I don't think it is the cable as I'm sure I've got decent connections.  I kindof think something is up with the monitor, but it is new so I hope not  :(
Not sure if it is in any way related, but I've noticed a high pitch noise coming from the screen at times also - sometimes it comes/goes with a resolution switch.  Not really noticable when the speakers are making some noise, but again a bit annoying when things are quiet.
Any suggestions would be great :)
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:Image twitch
« Reply #1 on: April 30, 2004, 03:45:33 pm »
Do you store it in a cold, dampish place like a garage?
It may be that the tube has got a little condensation on it. Try sticking an electric heater in it and see if it stops. Works for me. :P
Re:Image twitch
« Reply #2 on: May 01, 2004, 07:48:04 am »
The monitor was in a garage for a while...but now it is in my cab in my house, so it should be pretty warm!
coconut
  • Last login:August 19, 2004, 09:47:57 am
Re:Image twitch
« Reply #3 on: May 04, 2004, 09:53:57 am »
I know my screen jumps very slightly when there's a strain on the hydro in my garage, (i.e. furnace or a/c first turns on) then its right back to normal.  Since you said it is random, this may be a cause.  Next time it happens check to see if something with a heavy load just turned on.
Re:Image twitch
« Reply #4 on: May 04, 2004, 02:08:18 pm »
Thanks coconut, but I think I figured it out...basically I hadn't adjusted the v-hold since I set the monitor up some time a go.  I adjusted it slightly and it seems to have fixed the problem - I don't know why I didn't think of that before  :-[
