Author Topic: 25KHz + Games List  (Read 2812 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
25KHz + Games List
« on: April 28, 2004, 03:14:31 pm »
I am currently trying to decide what arcade monitor to purchase.
I understand that some games in mame will not work with a standard 15KHz arcade monitor.
Is there a list of games with required monitor frequency so i can evaluate if i really need to spend the extra for a mult-freq monitor?
rchadd
  • Made in Cornwall
Re:25KHz + Games List
« Reply #1 on: April 28, 2004, 03:18:43 pm »
in http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=18655
b3atmania advised:
Too many to list from memory, but here are a few:
- Atari System 2 based: 720 degrees, Paperboy, Super Sprint, APB
- Konami DJ-Main based: Beatmania games
- Sega System 24 based: Scramble Spirit, Hot Rod, Bonanza Bros.
- Sega Model 1 based: Virtua Fighter, Virtua Racing, Star Wars Arcade
- Midway Seattle based: Carnevil, NFL Blitz games
does anyone have a full list?
it would help me to make up my mind...
Serpent
  • Last login:December 02, 2003, 03:34:39 am
« Reply #2 on: April 28, 2004, 05:12:03 pm »
I think all games with a vertical res higher than 300 pixels.
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #3 on: April 28, 2004, 06:27:08 pm »
Wouldn't  Advmame solve the problem?
rchadd
  • Made in Cornwall
« Reply #4 on: April 28, 2004, 06:32:21 pm »
i think the monitor needs to be physically able to display the extra pixels that higher resolution games have.
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #5 on: April 28, 2004, 11:42:24 pm »
Correct.  The image can be displayed by either skipping some lines, or by interlacing, but either way it looks a lot better on the right monitor.
Here's a list of horizontal games with a y resolution over 300:
http://jstookey.com/arcade/sortinfo/index.php?num_switches=2&do_search=1&switch0=y&operator0=%3E&switchvalue0=292&boolean0=AND&switch1=orientation&operator1=%3D&switchvalue1=horizontal
rchadd
  • Made in Cornwall
« Reply #6 on: April 29, 2004, 06:14:09 am »
the list seems pretty long to me :(
can you display some of these games on std res monitor using ArcadeVGA by enabling interlacing?
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #7 on: April 29, 2004, 12:28:12 pm »
Have you seen the list of games that fit in the opposite category? (holy moly!) ;D
Absolutely.  All of these games will play fine with the ArcadeVGA in interlaced mode.  The flaw is that it's interlaced which isn't perfect (because of the slight flicker to the screen) compared to using the proper monitor.
