Author Topic: Coind Door Wiring, Question...  (Read 955 times)
Shredder
  • Last login:June 01, 2004, 01:10:15 pm
« on: April 15, 2004, 06:40:26 pm »
What wires do you need to startup free play?  One wire is a ground, and the other is a 'coin1' wire from the Jamma harness, correct?
I re-wired it to my free play start button, so I don't have to insert a quarter each time, and for some reason, nothing happens when I press it.  Could it be that the wire has to be setup a certain way in the Barrel Insulated Female Connectors?
SirPeale
  • Green Mountain Man
Re:Coind Door Wiring, Question...
« Reply #1 on: April 15, 2004, 06:41:57 pm »
Did you wire it to both the coin door AND this button?
Just the button alone?
Shredder
« Reply #2 on: April 15, 2004, 06:48:26 pm »
Nope, just the button alone.  And just a quick update.  I don't know what I was doing wrong....m aby I had the wires mixed up or something, but I got it working again...
Now if only I can figure out why I'm not getting any video with My JRok connector.  Everything on  that is hooked up properly...
SirPeale
« Reply #3 on: April 15, 2004, 07:39:27 pm »
Ah, maybe you had it wired to NC instead of NO.
