Author Topic: Two mice at once in Windows 98se?  (Read 829 times)
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
« on: April 12, 2004, 12:34:42 am »
Is it possible to run two mice at the same time in Windows 98se (I know, I know, I need to upgrade my Windows, but I bought Windows Me and am now a little wary of Windows upgrades)
I am hoping to run a PS/2 and USB mouse at the same time.
Any thoughts?
NoBonus
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re:Two mice at once in Windows 98se?
« Reply #1 on: April 12, 2004, 01:05:32 am »
Doh!  As far as I know, Mame Analog+ will work with multiple mice under Windows 98se, but only if they are all USB.  Mame Analog+ XP (on the other hand) uses a different system which has the ability to mix-and-match usb/serial/ps2 mice, however that's only for Windows XP.
Your 2 closest options are:
Use 2 USB mice with Windows 98se & Mame Analog+.
Switch to Windows XP & use your ps/2 and usb mice with Mame Analog+ XP.
Also, you could run XMame or AdvanceMame under Linux, which also supports multiple mice of different types.
NoBonus
« Reply #2 on: April 12, 2004, 02:25:06 am »
Thanks, I had tried to get on usb and on ps/2 mouse working before and it locked everything up, but I will try 2 usb.   Thanks again.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: April 12, 2004, 06:32:17 am »
You SHOULD be able to use one USB and one PS/2 mouse in Win98SE with standard MAME, they just will both "fight" over the Player 1 cursor.
That said, I had a problem with my single PS/2 mouse locking up the system at random intervals and switched to a USB mouse.  The problem I had occurred with 3-button and scroll wheel mice, and a mobo swap and windows re-install did not fix it.
