Author Topic: Optipac Trackball/Vortex Spinner Question...  (Read 915 times)
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« on: March 27, 2004, 03:13:01 pm »
Ok, this may be a dumb question, but here goes.
Do you have to have seperate grounds and 5v's for each device, or can you use just one 5v/ground, say from the trackball?
Also, does the Oscar need to have the optipac set to hi or lo?
Any help would be greatly appreciated.
OSCAR
    • Oscar Controls
Re:Optipac Trackball/Vortex Spinner Question...
« Reply #1 on: March 27, 2004, 03:39:10 pm »
As long as you get +5V & GND to the spinner optic board, that should be fine.  It shouldn't be necessary to run separate power and ground wires back to the Opti-PAC if you can get them from the trackball.
You can set the polarity jumper on the Opti-PAC to either Hi or Lo with my optic board, it doesn't matter.  Actually, you could remove the jumper altogether, but without anything connected to the Y-axis on the Opti-PAC header, the y-axis will "float" causing the cursor to drift in the y- direction as you scroll sideways.
