Author Topic: P2 button 5 & 6 not working  (Read 2158 times)
krick
  • Gotta have blue hair.
« on: March 21, 2004, 12:58:43 pm »
I can't seem to get player 2's buttons 5 & 6 working on my machine.  When I play any of the CAPCOM fighters as the second player, buttons 5 & 6 are dead.
At first, I thought that the problem was my J-PAC or my wiring but if I open notepad in windows and hit each of player 2's buttons in order, it types:
asqwik
So the problem isn't in my wiring or the J-PAC.
Any ideas where I should look next?  This is frustrating.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
crashwg
Re:P2 button 5 & 6 not working
« Reply #1 on: March 21, 2004, 01:32:54 pm »
Have you tried setting them up in mame?
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« Reply #2 on: March 21, 2004, 02:34:38 pm »
asqwik
I was having this "problem" before too and it so pissed me off, and I nearly made another hole in the wall (with my head) when I found out the "problem"/solution.  You just need to configure the two buttons  in MAME.  For some reason, by default (or whatever) those 2 buttons are not assigned automatically (anymore?).
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« Reply #3 on: March 21, 2004, 06:35:56 pm »
He is 100% correct.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: March 22, 2004, 08:19:37 am »
Out of the box, MAME is configured for Player 1 buttons 1-10 and Player 2 buttons 1-4, anything beyond this, you have to set up yourself.
krick
« Reply #5 on: March 22, 2004, 11:36:05 am »
Thanks all.  Got it working now.
I made an (incorrect) assumption because my J-PAC had "MAME default" settings that included 6 buttons for player 2.
Hantarex Polo 15KHz
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #6 on: March 26, 2004, 11:04:35 am »
The J-PAC does have default setting for these buttons. The problem is that MAME does'nt. Why, I know not. This is probably the number one support question for I-PAC / J-PAC.
I think I'll try to lean on the MAME devs to add these keys into the default setup. It would be really good if they were to use the keycodes I chose for the I-PAC defaults...would save a lot of support emails.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 27, 2004, 11:04:41 am »
Actually, I thought there might be a problem because the I-PAC defaults for P2 Buttons 5 thru 8 are the MAME defaults for P3 joystick movement, but since there are no 3 player or 4-player simultaneous arcade games with more than 4 buttons, this actually doesn't cause any problems.
