Author Topic: Programming-Remap IPAC 2 Help  (Read 3224 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: March 08, 2004, 05:24:18 pm »
Hello,
I have the old IPAC 2 and I can not seem to get it to re map buttons. I have tried changing the jumper to ALT. And running the WiN app. but it keeps saying FAILED! NO IPAC CONNECTED. I think i need to start from square one.
1. any one have a pic of exactly how the jumper should be set. maybe i have it wrong?
2. software using is  WINIPAC v1.0.16 is this correct? according to the web site it is.
i tried the dos version no luck just locks up. (i am using xp). and have tried slowing down the settings where its the speed it sends info to the ipac.
I have checked their msg board but nothing helped :(
anyone advise? I would appreciate it
Demon-Seed
Re:Programming-Remap IPAC 2 Help
« Reply #1 on: March 08, 2004, 05:36:28 pm »
well I went into options and since my board is older than Aug 1, 2002 I hit old. Now it tries to update buttons but keeps saying FAILED! Adjust download speed. I have tried every one... none work..
any suggestions?
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: March 09, 2004, 08:06:36 am »
any suggestions?
E-mail Andy.  His address is on the ultimarc site.
anitabill
  • Last login:June 15, 2012, 07:51:07 am
Re: Programming-Remap IPAC 2 Help
« Reply #3 on: August 18, 2005, 09:30:11 am »
I'm having this exact same issue.
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #4 on: August 18, 2005, 10:12:06 am »
I had a similar problem. I then realise that I was using the wrong programming software. To be sure that there is no problem with the I-PAC, simply set the jumper to mame and see if it works. If it does ... you have a problem with the programming software you are using, if not, you may have a short ...
