Author Topic: I-Pac Ultimate - can't get P3/P4 working? (SOLVED)  (Read 2452 times)
DrHogie
  • Last login:December 15, 2024, 09:05:59 am
« on: December 09, 2024, 12:04:40 pm »
Hello all -- I'm hoping I'm overlooking something really silly with this.
I just got done building my dream arcade cabinet.  I went with all Ultimarc parts for the controls because Andy comes very highly recommended.  I got everything wired up and went to WinIPAC 2 to setup the buttons.  I'm using an iPac Ultimate IO board, firmware 1.56, in a 4 Player configuration with no trackball or spinner (I have a trackball, but it's hooked up with a separate USB interface).
I'm using Retrobat for the emulation package.  I initially tried using the keyboard mode with the IPAC UIO, but couldn't figure out how to get P2-P4 assigned.  I learned how to swap modes on the IPAC UIO and got it swapped into XInput preset, and was able to get P1 and P2 fully setup and working.  However, when I tried to assign buttons to P3 and P4 in WinIPAC, there's no option in the dropdown for P3 or P4.  When I go back into Retrobat and hold down a P3/P4 button to assign the controller, nothing happens.
Is there some kind of setting I'm missing to get WinIPAC to let me assign P3/P4 buttons/sticks via XInput?  Or is there a way in Retrobat/ES for me to you the keyboard, but assign four different controls from the one keyboard?
Thanks in advance for any help!
DrHogie
« Last Edit: December 14, 2024, 01:20:56 pm by DrHogie »
MartyKong
  • Last login:February 09, 2026, 10:02:08 am
Re: I-Pac Ultimate - can't get P3/P4 working?
« Reply #1 on: December 10, 2024, 04:03:56 pm »
DrHogie, Will be watching this post as I also have a Retrobat setup that I eventually want to turn into an arcade. I have an older Retrobat version but also found it only allows for a single keyboard so no way to set up player 2-4. I'm surprised the xinput setting for iPacs doesn't allow for player 3-4. Maybe contact Andy for a solution.
KenToad
  • Last login:Today at 10:28:08 am
  • Flap Flap Flap
« Reply #2 on: December 10, 2024, 09:46:57 pm »
Does the iPac ultimate support 3/4 players through Xinput? I have an iPac 4 that apparently supports 3/4 players through Xinput because of a firmware update, but I haven't tried it yet.
DrHogie
« Reply #3 on: December 14, 2024, 01:20:24 pm »
You are absolutely correct!  I emailed Andy and he told me the UIO only supports 2 player via XInput.
Also, I found out that if the UIO is in XInput, it cannot perform any LED configuration either.  This was disappointing because I misread and assumed the “ultimate” board would be able to handle 4 player plus LEDs.  I have ordered an IPAC 2 that I’m going to use to run P3/P4 separately (which I’m having issues with that as well — but that’s another thread).
Thanks for the help!
