Author Topic: [SOLVED] Accidentally put 30Hz in my CRT monitor and now I can't see anything  (Read 2441 times)
Nodoyuna
  • Last login:November 29, 2025, 11:48:41 am
Hi all
I change today the refresh rate of my CRT Monitor from 60Hz to 30Hz by accident.
I'm in Windows 7 and with CRT Emudriver installed (I can't check version now)
The system worked perfect before, but now, with 30Hz, I can't solve the problem, as I only see lines in my PVM monitor.
I tried to connect the computer to a VGA monitor and restore the 640x480@60 resolution, but when I switch back to the PVM, the problem continues. Right now I have 74,87 (Horizontal) and 60 (Vertical), so it's a disaster.
I think my only solution will be to reinstall the CRT Emudriver, right?
I flahsed the GPU the first time I installed them, do I need to flash the GPU again?
I suposse the drivers and install procedure has changed from the first time I did, so where can I find a step-by-step guide to install the drivers?
Thanks in advance
« Last Edit: May 14, 2024, 02:37:50 am by Nodoyuna »
Nodoyuna
Hi
I solved the problem by reinstalling the CRT Drivers. Everything is OK now ;)
Hi all
Thanks in advance
