Author Topic: Adjusting Screen with ArcadeOSD ?  (Read 3454 times)
trev1976
  • Last login:December 07, 2025, 06:25:07 am
    • Girls In Your City - Anonymous Sex Dating - No Verify
« on: March 16, 2024, 03:50:30 pm »
Hi ,
My screen is off centre in GM and i've been messing around with ArcadeOSD today but I have a slight problem.
I can adjust the test screen fine and it looks great but when I go into a game its back to off centre.
I managed to get the desktop resolution to stick but not the games.
I have a work around at the moment,  where I can go into a game , go back to desktop and open ArcadeOSD and adjust and that works but once the game is shut down its back to being off centre.
Any ideas ?
Thanks 😊
https://SecreLocal.com - Chat Local Singles - No Verify - Anonymous Sex Dating -   Dating Chat Local Live
buttersoft
  • Last login:Today at 04:39:06 pm
  • Is running at 15kHz
Re: Adjusting Screen with ArcadeOSD ?
« Reply #1 on: March 16, 2024, 09:17:04 pm »
there is a guide to VMM and ArcadeOSD - http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=46
VMM sets up modelines and installs them. ArcadeOSD adjusts them. And you can save the adjustments. But the switchres utility in GroovyMAME, which is where the magic happens, uses the timings in the mame.ini file. When playing with ArcadeOSD, remember that Esc will back out of any changes.
To make adjusted timings stick for GM you can either redo VMM with updated timings in the monitor.ini, or instead you can just edit the mame.ini file with the updated horizontal timings (starting with the crt_range0 line, which for the generic_15 monitor preset defaults to crt_range0 15625-15750, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576 - remember that your monitor may want a different preset, and that any specific vertical.ini, machine.ini like neogeo.ini, or game.ini files will override). Calamity insists redoing VMM works best, but i find that with the spread of modes i'm using (230p at 60Hz all the way up to 600i at 50Hz) on different monitors, i still want to set the mame.ini timings afterward.
trev1976
« Reply #2 on: March 17, 2024, 10:58:53 am »
Hi
Thanks , I think I've sorted it.  Not sure if it's the correct way but it worked.
Adjusted via ArcadeOSD , copy to clipboard and then enter values into my mame.ini crtrange.
Had to delete a few lines of text to get it right but seems good.
« Last Edit: March 17, 2024, 03:18:15 pm by trev1976 »
Rion
  • Last login:Today at 07:28:42 pm
  • 240p, 480i
« Reply #3 on: May 19, 2024, 12:19:19 pm »
Why not use the geometry tool with switchres?
trev1976
« Reply #4 on: May 20, 2024, 03:45:13 pm »
How do you use it ?
