Good evening-
So I got a new screen and it is causing some oddities. Same box was previously using a different panel, and LCD Range / HW Refresh were working exactly as intended. I got a LG Dualup monitor and have it rotated to approximate a big 4:3, so Windows is running rotated.
As far as I know, I'm using the same INI config and everything else is the same, but it absolutely refuses to create new modelines now upon game launch. I tried putting the screen to its native orientation as well to see if that was somehow affecting switchres, but no luck. The panel can verifiably sync at least as low as 54hz tested in OSD... and if I create custom resolutions by brute force with Radeon software, Groovy will still elect from those... but can't figure out why HW Refresh is no longer working and dynamically generating. Representative Rtype log attached.
Since getting this screen, Groovy also hangs on the command line upon exit. Not sure whether that is related. May also have to do with the old card running it at the moment... but it has a more modern successor coming sometime this week to drive this screen.
(And no, notwithstanding its other cool features, the display doesn't support any formal VRR)
Thanks-
