Author Topic: Defender - cocktail  (Read 3259 times)
spisi
  • Last login:December 07, 2024, 06:45:34 am
Defender - cocktail
« on: August 09, 2023, 01:27:34 pm »
I'm trying to get Defender to work on my MAME cocktail table. I can't seem to locate the correct rom that has the dip switch option. I've tried the red and blue label roms to no avail. Any help would be greatly appreciated.
spisi
Re: Defender - cocktail
« Reply #1 on: August 09, 2023, 01:38:30 pm »
Just tried white lagel - no luck there either...
  • Last login:Today at 04:37:02 am
« Reply #2 on: August 09, 2023, 07:17:33 pm »
This is a known issue.
https://mametesters.org/view.php?id=7721
There's no dipswitch menu because Defender used three jumpers instead of dipswitches to set either upright or cocktail mode.
On the Interface Board, upright vs. cocktail mode is determined by whether jumpers W1 and W2 were installed or removed.
- W1 and W2 are shown mid-lower right side of the schematic on page 14 of the manual here.
On the CPU/Video board there is a W1 "Screen Control" jumper on page 10 of the schematic here (1/3rd down the page, just left of center) and page 6 shows the physical location of W1 "Screen Control". (between ICs 5B and 5C)
- The theory of operation for W1 "Screen Control" is covered on pages 17-18 of the manual here.
One of the MAME devs could possibly implement these three jumpers using a "Machine Configuration" menu entry to select "Upright" or "Cocktail" like they did for Asteroids starting in v0.198.
http://forum.arcadecontrols.com/index.php/topic,157459.0.html
Until they get around to doing that, you might be able to use MAME's fake "Cocktail" video mode and map the P1 inputs to work with both P1 and P2 controls.   :-\
spisi
« Reply #3 on: August 09, 2023, 08:14:04 pm »
Bummer.....
spisi
« Reply #4 on: August 11, 2023, 03:31:36 pm »
What's the odds that the devs will work on this? I would have thought it would have been addressed by now, no? Is there a chance it will never happen?
« Reply #5 on: August 11, 2023, 07:06:28 pm »
I wouldn't hold my breath waiting for it.   ::)
The Defender cocktail mode issue here was opened in MameTesters three years ago.
Current status is "Acknowledged" (Has been processed and some testing has been done, but there has been no final determination made as to it's status.), but almost all of the other open "Flip Screen/Cocktail" issues are "Confirmed" status. (Another tester or moderator has determined the bug to be valid.)
Of the 44 "Confirmed" status "Flip Screen/Cocktail" issues, 37 are older than the Defender issue, some going back to 2008.
On the positive side, it looks like getting screen flipping to work is just a matter of either adding or removing the W1 jumper connection between pin 8 of the 7474 Dual-D Flip-Flop IC at 4E and pin 9 of the 7404 Hex Inverter IC at 5B on the CPU/Video board.
The hard part is figuring out where in the MAME source code that jumper connection is made/broken.   :dunno
EDIT:  Another possible approach is to use a LUA script to flip the screen during P2's turn.
It might be possible to incorporate this into a version of the "defenderlr" script that works with both Defender and Stargate.
https://github.com/AaronBPaden/defenderlr
https://github.com/10yard/defenderlr
http://forum.arcadecontrols.com/index.php/topic,165767.0.html
Haven't looked very deep into the Stargate schematics, but it looks like it doesn't use dipswitches for cocktail mode.  The Drawing Set here shows data lines labeled "Screen Control" (page 7 left middle, page 8 lower right) and there are two notes on page 9 that say, "Use W1 for upright applications."
« Last Edit: August 11, 2023, 08:27:34 pm by PL1 »
spisi
« Reply #6 on: August 12, 2023, 06:01:41 am »
Thanks Scott, I think I can figure a way to flip it myself using hot keys (ctrl+alt+down arrow)...
spisi
« Reply #7 on: August 23, 2023, 12:08:12 pm »
Man, the game switches from player one to player two really fast....I have to pause then flip then unpause. What's the odds this ever gets fixed?
« Reply #8 on: August 23, 2023, 01:33:11 pm »
Fixed by the MAME devs?  Odds are very low.
Workaround using LUA?  Sent a PM to Jon (10yard) 11 days ago asking if it is even possible but haven't heard back from him.   :dunno
