Author Topic: TurboTwist2 Smart-X with older GGG trackball install - pinout/wiring  (Read 1499 times)
Daniel B.
  • Last login:May 10, 2024, 05:08:12 pm
  • Lightgun and Point Blank enthusiast
Hello,
I've read the excellent information in this thread - http://forum.arcadecontrols.com/index.php/topic,114457.msg1214268.html#msg1214268
My question is wiring the trackball to the board using the following wires seen coming from the unit:
x1 Yellow, x1 Green, x1 Blue, x1 Brown, x2 Red, x2 Black.
I am ok to merge the RED/BLACK to a SINGLE 5V connection on the smart-x encoder? looks like in the J2 area, pins 1/11 are 5v and pins 2/12 are ground. I can extend the wires to each port if I need to, but I am hoping to power the 5v "Electric-ICE TB RGB-Drive", with one of the 5v pins on the turbotwist2.
I think I am clear with the colored wires based on Randy's answer on that thread:
Each optical PCB requires it's own 5v supply, so these are split off to each from the Opti-Wiz.  The pairs are yellow/green and purple/blue.  If the trackball directions are reverse, simply connect the yellow where the green was, and vice-versa.  Same for the purple/blue pair.
Its been AGES since I've messed with these items and I just wanted to see if anyone had thoughts on this, or if I am safe to try it. Would hate to hurt the RGB module, or even worse the smart-x controller.
Thanks and Happy New Year!
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
RandyT
    • GroovyGameGear.com
Re: TurboTwist2 Smart-X with older GGG trackball install - pinout/wiring
« Reply #1 on: January 02, 2023, 02:37:53 pm »
Yes, you can run both of the optical sensor board power lines together.  It's even done this way on the OptiWiz trackball harnesses we offer.  Just make sure you observe the proper polarity ;)
Depending on which trackball lighting unit you have, and how much of it you are using as (correct me if I'm wrong) you are using it in a static lighting implementation, it may or may not be wise to power it from the Opti-Wiz.  I'm sure that doesn't help at all, but it sets the stage for the answer.
The Opti-Wiz3 really isn't really designed to deliver power to higher current LED lighting.  If you will be using 1 primary color, it should be fine.  2 would possibly be ok as well, as would be the case for cyan, magenta or yellow, but trace temperatures on the PCB should be checked to make sure it's not getting too warm.  But I would be very careful if powering all LEDs simultaneously for white, for extended periods of time.  You might get away with it, but you will need to pay close attention to how well the PCB is handling the current.  If it's only slightly warm in that configuration and the USB port isn't overloaded, even that will probably be fine.
Daniel B.
« Reply #2 on: January 02, 2023, 02:48:28 pm »
This is exactly what I needed. I will deliver the 5v for the led from a dedicated source in my cabinet. I'm currently just playing with a quick hack panel to play with the new spinner and its portable! I'll likely just skip the trackball lighting for this little controller and do it proper on the cabinet.
